2008 head unit vs older head units.
Connector is not the same, so some modification will be required. You will need wiring harness connector from '07-08. Then find pinout from both of them and compare.
Compass will not work. You will have just circle and a car.
There is thread about it somewhere in the forum.
I got the clip from the 08 that the display came out of. I have the part number for the compass, I've looked it up but can't figure out where on the car it is located in order to remove it from the part out.
Anypne know where it is?
