2008 acura tl bluetooth bad
Old Dec 27, 2017 | 05:35 PM
mharrod45's Avatar
Bad and needs to be replaced
Old Dec 27, 2017 | 09:33 PM
svtmedic's Avatar
Don't bother to replace it. Not worth it. It will go bad again. Next. Get a blue tooth and call it a day. End of report.
Old Dec 28, 2017 | 04:26 AM
Joecop67's Avatar
Make sure you disconnect it.
Old Dec 28, 2017 | 10:01 AM
RobPE's Avatar
Definitely disconnect it. Known issue is when they go bad, they can kill your battery since it draws power, even when car is off. Acura will charge you a bunch, plus it is old BT technology - can't stream music, etc. I just installed a US Spec BT45-HON3 and so far, so good. Cost less than the refurb'd Acura BT.
Old Dec 29, 2017 | 04:49 PM
mharrod45's Avatar
RobPE, Thank you for the insight. The new module you installed! Where did you find it. Mark
Old Dec 29, 2017 | 05:03 PM
Joecop67's Avatar
I bought mine from amazon. It costs more from crutchfield but they are an authorized seller.
Old Dec 29, 2017 | 06:04 PM
RobPE's Avatar
Mark - got mine at Amazon. Here's the link:
Amazon Amazon
I thought about Crutchfield since they provide install support (which was more important back in the day before the internet), but this install is not bad as the XM Satellite receiver sits in the trunk in the passenger side 1/4 panel. It allows you to wire up a USB charging port and AUX input (cables are extra). If you go with it and have any install questions let me know - just finished installing in my '06.
Ron A
May 5, 2026 07:11 AM
TSX69
3G RLX (2013+)
1409
Aug 17, 2020 12:49 PM
csmeance
1/2G MDX (2001-2013)
63
Oct 6, 2018 05:13 PM
EvilVirus
Aug 16, 2017 10:38 AM
rets
Jan 1, 2013 09:50 PM
