2007-2008 acura tl s rear view cam question
I have a 2007 acura tl type s the rear view camera doesnt have lines showing where i can go, but i noticed that in one of my friends 2008 acura tl type s he had the lines. Someone had told me there was a way i could get the lines put in? if anyone coulld possibly help me with this
I haven't seen an 2008 TL-S with lines in the rear view camera. Are you sure he doesn't have an aftermarket setup? The new 2009 TL has them, but that is overlaid by the navi system
If it's overlayed by the navi system, does that mean the navi dvd itself? If so, could it be because he had the updated 2010 navi disk? Just throwing out thoughts here.
I was thinking the updated version for 2007 model cars, not the actual disks from the 2010 models....
http://www.navigation.com/is-bin/INT...gationMenu=YES
It looks like we can update to the 2010 White DVD Map Update v4.81
Not saying that this will give the lines, but just pointing out that there is an updated disk we '07 owners can purchase.
The new TL uses a hard drive based system, so it's probably overlaying the data and not the camera itself. Converting to a HDD system from the 2010 TL will be nearly impossible since the HVAC and Navi controls are handled completely differently.
Acura Cert MASTER TECH
I have the v4.81 and i can confirm there are NO lines. I also have a 2010 TL back up cam for my front cam mod im going to do at some point and i tested it and found there are no lines using that cam either. So between that and a bud of mine that told me it can be toggled on and off in the controls of the 09-10 TL and said its in the system.. with that said not sure if there is anyway to make this happen then unfort
Additionally, the "disc" for the 09/10 TLs is simply an update disc, it is not used to actually run the system, like our outdated systems
