2006 TL Navi Hack
Old Oct 17, 2017 | 09:24 PM
ckoulaid's Avatar
2006 TL Navi Hack
I have an 06 TL w/ navigation.
Issue: Unfortunately, when I moved to HI the navigation no longer works and there isn't an update to include Oahu. My options were get a 1. new in-dash navi, 2. replace with 2007-2008 navigation or 3. hardwire portable navi
Solution: #3 Hardwired Garmin to give a similar look to Mazda 3 or BMW navi. Total cost= $360 (Drivesmart 61 plus materials)
Process:
  1. Drilled hole in dash to pull the power cord through.
  2. Used an add-a-fuse and socket in the fuse box area (driver side)
  3. Mounted navigation with 3M and Sugru (moldable rubber found at Target or Amazon)
Result:
  1. 6.95" Touch/ Voice activated navigation w/ traffic.
  2. Powers on and off with ignition
  3. No visible cords
  4. View is not blocked
This may not be for everyone because you do lose the top center screen w/ clock and temp, but for me it was worth it to have navigation.
View from outside. I think much better than the Garmin mount.
Another shot of the setup.
Old Oct 18, 2017 | 11:18 AM
Jackass's Avatar
Great functional addition....I would be more worried about the temptation for it to be permanently "borrowed" when out and about.
Old Oct 18, 2017 | 07:10 PM
ckoulaid's Avatar
Yeah, "borrowing" is always a possibility/concern. I'm hoping the fact that there are no wires and it is firmly attached to the dash will be a deterrent, i.e. can't snatch-n-go like a suction mount GPS.
