2005 Acura TL DVD-Audio
Okay so first of all i have done my research and read so many different things that i got kind of confuse. before i had read anything i tried burning a mp3 CD and AAC CD and DVD+R and when i did my research found out 04-06 models don't play mp3's. Then i read that if you convert you mp3's into ISO image and burned them that they would work. the software i used let me burn the ISO image as an ISO burn or DVD burn. I tried both on the DVD+R and no luck. I have read that some people got DVD+R to work and since i had like 50 i tried using them but no luck. Any of you guys had any luck with DVD+R?? By the way i already ordered the DVD+R cd's to see if i can get those too work.
okay so i have a program where i can convert my audio files. So if i convert them into wavs. Then i have a program that's called create-burn iso image. So when i put the files in the program to burn them. It gives me three options, "create iso file" where it would turn the wavs into an iso file. then "burn iso" and "burn cd/dvd"... which one should i use? and also are you doing this with a dvd+r or dvd-r?
justnspace has it right.
No, you didn't do your research. Search "Adobeman's DVDA".
I have downloaded Adobeman's DVDA and i can't install it because i need to install .net framework 1.1.4322 and i can't find it anywhere. The link on his page is not good and microsoft.com doesn't have it. i tried downloading 1.1 and 4.0 from their sight but the adobemans program still doesn't install it says i need 1.1.4322. So i'm trying to see if there's a way i can make it on my computer with my programs. i'm not interested in the 6.1 surround. i just want to fit a lot of songs on a disk. like i said i could convert them to wav and then into ISO. i just don't have a program that burns DVD-A. I could burn the ISO into DVD+R as data but i don't think it will work.
I found a software for mac that's free and create DVD-A disc. I haven't tried because i have windows. http://burn-osx.sourceforge.net/Pages/English/home.html
Try here:
http://www.92hi.com/downloads/dotnetfx.exe
Install SP1 from here:
http://www.92hi.com/downloads/NDP1.1...867460-X86.exe
n00b
I tried a bunch of stuff with the audio system. I administer a surround sound website so the surround sound aspect of the ELS system has always been important to me. Since I've owned an 04TL (First ELS system), an 05 RL (Bose surround system), 07 RDX (2nd Gen ELS system) I am always curious about the differences. Now with this 3rd generation ELS system I gave it a real test. Some disappointments ensured.
First off, I was hoping that with the "death" of DVD-Audio, they would have removed the watermark (copyright protection) circuits from the deck so that it would play copies of DVD-Audio discs. Many new home players (Oppo for example) do not have this circuitry and will play DVD-A copies. Unfortunately, the ELS system still has this crap in it, and a copied DVD-A stops and ejects after 10 seconds or so (as it should).
And no, Adobeman software is creating a disk not directly copying, or disk to disk copying.
DVD-Audio Created at Home
First my question. Has anyone created a DVD-Audio for our ELS systems with a DVD-R DL disc? If so, does it work?
Second, my response to one of the posts on here that says our system can't play burned discs. I've made about 10 DVD-Audio discs burned on my computer. I take DVDs I own of live concerts and then do a bunch of conversion (that's a whole separate discussion) to create my DVD-Audio discs (yes the car says DVDA on the screen and the 5.1 sound is clear). My favorite is Pink Floyd's Pulse concert...sounds amazing in the TL in 5.1.
For those thinking of creating their own DVD-As,there are a bunch of good tutorials on this forum...Adobeman has some good tutorials but I ended up doing mine after a combination of what I read across the TL forums and some Google searching. Anyway, it works...just make sure you use DVD-R discs...not DVD+R.
DVD Audio Solo is a good tool, too.
Never tried Fox Tab---I use Fairstars Audio Converter---but any good audio utility works well. Use what you're familiar with---hell, I think even i-Tunes lets you convert formats.
Note that Adobeman also has a script tool available to turn 2 channel wav into simulated 5.1. It works pretty well with studio recordings. Live recordings tend to already have a certain "washed-out" quality to them that doesn't play well with the algorithms.
Both of the Adobeman tools are very good quality and have served me well. Kudos to him for making these available!
Keep Right Except to Pass
I used to use Adobeman's GUI on my old Vista PC. Got a new PC this spring and it runs Windows 7 and I had trouble getting the .NET framework 1.1 to run on Windows 7, so I wound up springing for HD-Audio Solo Ultra (which will also created simulated 5.1). I thought about Discwelder until I discovered that Discwelder Bronze allows only one group per DVD. I depend on the multiple groups so that I can use the DVD-As to carry large amounts of CD audio on fewer discs. The Cirlinca software is $35 cheaper than Discwelder, too. I find it to be somewhat more convenient than Adobeman's because it burns and finalizes the disc for you in addition to creating the .ISO image, but on the other hand Adobeman's is free. Either one should work quite well for more people. On my old PC I used dbpoweramp to convert file formats.
As an aside, my new PC has a LightScribe drive and it's quite the useful feature when you're putting as many as 11 CDs on a single DVD-A.
i kinda have to lol at the fact that acura promotes itself as high tech luxury, but in 2006 they had a tape deck and not a aux port or ability to read mp3.
.MP3 is a low-fidelity format and does not belong in a car being marketed as a luxury vehicle. Anyway, they're not marketing to 20-something year-old kids.
Acura was behind the times with this one. In 2004 they just barely could "get away with it" since not everyone had added aux ports and mp3 capability. However its a sore excuse for a company that wants to be seen as a tech leader.
Seriously? mp3 even in 2004 was a pretty big deal. Its not just a 20-something thing. Wasn't then and isn't now. Yes, its a lower fidelity format, but I'll bet you $100 that you can't do much better than chance vs 320kps mp3 in a proper blind test. Other "lesser" makes had this tech in 2004. When the car came out how behind the times a cassette deck is was a common topic on the boards.
.MP3 files have their place. If I have a choice between an .MP3 concert bootleg or no bootleg, then I'll take the .MP3 version. It's better than nothing. But when they put in a stereo that plays a high-rez format, it would be rather inconsistent to put in the capability to play a lossy-compressed format (which by definition is inherently low-rez).
Coolest A-zine Member
It doesn't matter whether it was a "pretty big deal." It's a low-fidelity format and they opted for DVD-Audio instead. I don't see why some people get so worked up about the tape deck. Who gives a damn? If you don't want to use it, then don't use it.
Thank god they opted for DVD-Audio! Love some lossless audio
I mean if I had my choice, the tape deck wouldn't be there...but it's not a big deal. It says Acura on it and doesn't look as bad as it could. Sure, tapes were something of older days, but I'd rather have a tape deck and DVD-A then no tape deck and aux port! MP3
I just built a beast of a PC and I've used mac for the past 3 years so I'm on the hunt for the best free programs to convert files from FLAC -> WAV and then burn the iso/DVD-A. Wish me luck
For burning the .ISO to the DVD you don't need anything special—any burning software should do the trick because you're just burning a file to a disc (a very very big file, true, but still just a file). The special software is needed to create the .ISO with the necessary structure. I use Cirlinca's HD-Audio Solo Ultra to create DVD-As and it will burn the disc for you as part of the process. It's not free, but it's been very reliable. I used to use Adobeman's software that's available elsewhere on this site, but when I got a new PC earlier this year I had trouble getting the necessary version of the .NET Framework to work with Windows 7, so I gave up and bought the Cirlinca software. It's been well worth it, as I burned a bunch of DVD-As in June in advance of a trip to Florida.
I haven't dealt with much FLAC stuff since I got the new PC and so have no recommendation there.
One big nuisance for me if I transfer any of my old mixed tapes to DVD-A is that I used to challenge myself to make the gaps between the tracks as short as possible. I can think of at least one mixed tape I have where the end of "You Shook Me All Night Long" cuts DIRECTLY to the first chords of "Who Are You" and it sounds like it's a single track. Problem is, unless I sit in front of the CD recorder and manually insert all the track breaks, I wind up with the tape transferring as a single track because the CD recorder doesn't encounter enough silence to realize it needs to break the track there. It's hard to find the time to sit down there with the remote inserting the track breaks. So if I want to listen to one of my old mixed tapes, I usually just bring it with me. Yes, I HAVE used the TL's cassette player from time to time! The only real nuisance is when I want to play a tape that I recorded using Dolby C Noise Reduction. The TL's tape player, like most car tape players, only supports Dolby B.
I get a little tired of people claiming they hear dramatic difference between high bit rate compressed audio and lossless audio though. Seriously try a blind comparison some time. I was totally in you camp until I did real ABX testing and found out those differences are pretty much impossible to spot if you don't know which one you're listening to ahead of time. Blind is incredibly important as you *will* hear differences if you know what sample is being played. I did the whole testing thing in small steps to determine what quality I should compress my cd library at and found by 256k I was doing barely better than chance. By 300k It was chance.
Legend2TL
11-20-2015 07:31 PM
handsom-hustla
11-13-2015 05:04 PM
nuldabz
09-03-2015 05:49 PM
