2004 1TBO Radio Problems
I have a 2004 with plate number 1TBO. The radio's buttons don't always work. I can't always turn it off, switch am/fm, cd, etc. CD changer works great, so does the unit. I just turn volume down to "turn it off". Also the wheel controls always work so I can always use those. Anyway have these problems before?
I see faceplates can be replaced as i see them on e-bay. This unit has already been into the shop about 3 years ago and was sent in as the cd changer unit died on it. Other than that.. the radio works fine... Thoughts...
Registered but harmless
Received 1,149 Likes
If you have Navi and a working HFL, you can use voice commands to turn the radio on/off as well as switch sources, stations and discs.
Voice commands are only available with the Navi option, and use the mic in the HFL unit.
Otherwise, it sounds like a radio faceplate assembly issue.
Thanks for the feedback. I am non-navi...
Does anyone know how to replace the faceplate on these? Is it an easy job? Can it be done w/o pulling the radio?
