2 12w6 or 1 12w7?
Old Feb 19, 2009 | 07:13 PM
ezland00's Avatar
2 12w6 or 1 12w7?
Well.
i'm trying to get 1 12w7, but twice the sub arrived broken. I am now considering 2 12w6. Should do it?
Old Feb 19, 2009 | 08:59 PM
Trew's Avatar
most definitely. you will be much better off with 2 12w6's. Just make sure you can find an amp that can dish out 1200w at 4 ohms. If not, get 2 amps - 1 for each sub. 600w @ 2 ohms each.
TypeSinNC's Avatar
Have you looked into any other subs? How much are you looking to spend?
Old Feb 19, 2009 | 09:02 PM
Trew's Avatar
Don't let anyone sway you on brand. you've made a great choice already!
Old Feb 19, 2009 | 09:05 PM
eggyhustles's Avatar
can't go wrong with with the w6. other good stuff out there too
Old Feb 19, 2009 | 09:32 PM
CSWBiggs's Avatar
2-12w6v2's will be louder than a single 12w7...
-Jason
Old Feb 19, 2009 | 09:36 PM
TypeSinNC's Avatar
i 2nd CSWBigg's post...you planning on going ported or sealed?
Old Feb 19, 2009 | 09:50 PM
Nick337's Avatar
it will sound louder, not better than the w7
Old Feb 19, 2009 | 09:59 PM
w6 sounds alot better
Old Feb 19, 2009 | 11:12 PM
TypeSinNC's Avatar
w6's do sound better than a W7...they're geared more towards SQ and the W7 is more of an SQL woofer...
Like always tho...the install has everything to do with the sound. Neither will sound good in a cheap prefab enclosure, so be sure the enclosure is built to woofer specs...
FYI...a member on DIYmobileaudio.com has (2) 12w6v2's, (2) 500.1's, and a sealed enclosure for $650 . JLs don't hold their value very well in the DIY audio world...
Old Feb 19, 2009 | 11:53 PM
650 is a steal for all of that
Old Feb 20, 2009 | 03:37 PM
ezland00's Avatar
thank you all for the advise. i already have JL 1000.1v2. will 2 12w6 do ok with this amp? I am planning to build 1(w7) or 2(w6) sealed corner fiberglass box. i know one of our vendor sells it, but i don't have $400-$800 so i decide to try DIY.
again thank you all.
Old Feb 20, 2009 | 03:46 PM
Trew's Avatar
It will be fine, but you will have to wire up the DVC at each sub to 8 ohms, then connect the subs to the amp output in parallel to bring it down to 4 ohms.
Unless the 1000.1 will be stable @ 1 ohm? I'm not too sure about that.
Old Feb 20, 2009 | 04:25 PM
TypeSinNC's Avatar
I'm not sure either but I think the 1000.1 puts out the same wattage from 1.5-4ohms (JBL amps are like this also)
FYI...it would be louder if the subs were facing the rear of the car. Have you ever done any fiberglassing before?
Old Feb 20, 2009 | 05:36 PM
Trew's Avatar
This is correct. That's why I'm not sure about 1 ohm. I'm sure Jason or eggyfussles (oops - typo) would know for sure.
Old Feb 20, 2009 | 06:00 PM
msala524's Avatar
08 TL-S NBP
haha, I would say a great deal of the type of sound comes from the type of enclosure. I have a w3 with only 250 watts and it sound at about 500. Its pretty impressive once I tell people what i got in there.
Old Feb 20, 2009 | 08:20 PM
TypeSinNC's Avatar
I WOULD NOT run that amp @ 1ohm...however you will have some ohm rise depending on the enclosure.
Old Feb 21, 2009 | 12:19 AM
CSWBiggs's Avatar
it would run fine...but just ask yourself...y you would want to do that!
what does 500 watts sound like? and how is it different from 250 watts...that comment made me rof and laugh...
do you want it to sound good or do you want it to bang? are you willing to deal with rattles?
-Jason
Old Feb 21, 2009 | 10:04 PM
but yeah, it does rated power from 1 to 4 i believe
2LOW4U
Jul 15, 2005 03:41 PM
dnd2984
Jun 30, 2005 12:05 PM
nippon_wa
Apr 3, 2005 10:39 PM
cu2g8rguy
Feb 14, 2005 02:07 PM
Austin519
Oct 3, 2001 05:20 PM
