12 Volt Power Source
Old Apr 18, 2005 | 07:40 PM
kimmarc723's Avatar
6th Gear
Question 12 Volt Power Source
Hi,
Need a little help. I have a 02 TLS and installed a dvd playerunder the seat. Can I wire it to the fuse box in the car? If so which fuses do I attached the wire too for battery and accessory power.
Old Apr 19, 2005 | 10:07 PM
kimmarc723's Avatar
6th Gear
Figured It Out
Ok,
I figured that out. Should have done a search One more question. Installing two headrest monitors and want to run power straight from the battery. If I use an inline fuse and run the montiors parallel, would it damage the monitors in any way. Having to much trouble trying to figure out which fuse position to use. Keep blowing fuses.
knight rider
Mar 4, 2016 08:59 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
