'07 TLS Harness Help
I'm in the process of having my double din radio installed. My installer said the instructions that came with the Crank It Up double din kit for retaining factory Nav are incorrect (atleast for the 07 TLS). I did some research and on DIYMA GaryMac said that you need to connect c9 and c29 to a 68 ohm resistor on the 40 pin harness. Would anybody happen to have a wiring diagram or know what colors those 2 wires are? Thanks...
Found it... https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/radio-harness-diagram-812329/
Also, I have a one day pass to the online service manual, if anyone needs any screen shots let me know.
the pin is backwards, i can send you the diagram, it works perfect, my email is xxxbusa@gmail.com, send an eamil to me
xsilverhawkx
09-28-2015 06:51 PM
