07 TL-S Remote Starter
Let's Go Pens
Does anyone have one of these installed? If so, please provide the brand name/features etc. I have a viper 791XV installed in my '04 Envoy and besides making the mistake of having the morons at Princeton Best Buy install it I love it. I'm considering purchasing one for the TL but I have had many people at the dealership suggest not having one installed because of acura electrical system.
Suggestions/Comments?
I don't have it on my TL-S, but If I were to get one I would purchase the CompuStar Remote Start/Alarm and purhcase their new CompuTrack service which allows you to start/stop your car from anywhere you have internet or a cell phone, as well as track your car if it is ever stolen, or even disable it from being started. Go to www.compustar.com and check it out. I have there older version in my Integra, and the remote start works great and mcuh further then any other remote start (atleast a couple years ago - but with computrack, starting your car from your cell phone is pretty nice if your in a building and the remote start key phobe won't reach).
I actually install remote starters/alarm systems on the side, and here are the brands I recommend:
1) Compustar 2WSS-AR (alarm and remote starter)
2) Viper 791XV/DEI products (Directed Electronics makes Viper, Clifford, Python, etc)
3) Ultrastart (for ease of installation, NOT for features)
As appropriately mentioned, you need an immobilizer bypass module, and the CAN-SL2 is awesome (i've used this several times on Acuras). It just connects to a brown data wire, and from this module (Approx $100) you can tap into doorlocks/trunk popper/windows/tachometer/etc.
There are several other types of bypass modules (and data interface module combos) made .. go to www.bypasskits.com and the sky is the limit.
There is absolutely NOTHING wrong with installing a remote starter/aftermarket alarm in the TL. The Honda/Acura immobilizer bypasses used to be a bit finicky (a year ago or so) such that after installing the immobilizer bypass unit the Acura/Honda would then erase a code in the ECM and cause you to have to get your car towed to a dealership to re-flash the ECM. The CAN-SL2 has resolved this issue as have several other bypasskit modules. You'll be fine.
The Compustar 2WSS-R is a 1.6 mile (range), two paging system that uses 900mhz frequencies to initiate the remote start sequence. I find this to be FAR superior to the 433mhz systems used in less expensive units.
Best of luck.
Best of luck.
oh, and key features you should look for in a r/s (remote-starter):
1) starter-kill/anti-grind --> so you don't grind the s**t outta your starter when getting in an already running car.
2) > 1.0 mile range and > 433mhz frequencies
3) two-way paging system
4) auxillary outputs ( > 2 is pretty good) --> for window roll-down modules/roll-up, defroster
with programmable latched or pulsed modes
5) external shock sensor (pluggable modules .. rather than having the shock sensor built into the r/s brain)
and for the record, I solder all my joints and feel that this is the ONLY way to install an alarm/remote starter -- anyone that uses T-taps or scotch taps is "ok" .. but they fail over time. As my buddies in the alarm business tell me all the time, the quality of a r/s-alarm system is only as good as its installation.
Let's Go Pens
Thanks for all the help. I think i'm going to go with the compustar, I especially like the Computrack feature. This will save me a some money on Lo-Jack and It will cover everything in a nice little package.
Hello Evader,
Did you get your compustart installed yet? I'm thinking of getting mine done next Tuesday at Car Trenz in Alexandria. They are an authorized pro shop. www.cartrenz.com.
Let's Go Pens
Originally Posted by 33scottie33
Hello Evader,
I stopped by Car Trendz this morning and they told me $950 to install the P2WSSR. When I called last week, I was told $1000. I seem to always get a better price by coming in person.
I'm a little hesitant because they told me that I will not have the feature to automatically open or close the windows/sunroof from the FOB. And you can't unlock just one door, you have to unlock all of them. Other than that, it seems to be pretty good.
Hello all,
Just a little background on myself, been installing for many years (17 yrs), worked for high end car audio shops and currently the install trainer now for best buy.
there is nothing to be worried about installing a alarm/remote starter system in these cars, ive done plenty.
I've recently just ordered the clifford avantguard 5.1 with the smart windows and garage opener, i will post detailed pics and wiring info for this. (just wait till the weekend)
I know this is not a page-back unit, but, i don't care that much, i just want one of the best alarms for my car (this ones fully programmable through my laptop).
as for the bypass, i've chosen the ' i-datalink' module, this does the locks, trunk, immobilizer bypass and alarm bypass. This unit also does not require a key to be cut and has been reliable.
If anyone has any questions about wiring info, pm me. but, install will be up soon!!!
Best of luck.
Best of luck.
In chicagoland you can go to bestbuy, circuit city .. I dont know of any smaller shops personally, but i'd post a new thread and ask the chicago peeps if they do...
Oh, and as far as liability is concerned, if you install the Computrak module on the Compustar and stop the engine and the thief is injured or killed, the OWNER of this vehicle is liable. This is called Anti-jacking mode, and I NEVER EVER NEVER install this feature. It's sad that this is the way the law works, but it is what it is.
The unit itself is $250, the bypass is $30.00 and the CAN-SL2 is $45.00. They're charging a ton of money for the install -- even if they ARE soldering every wire joint (over the scotch/3M t-taps) .. it's not work $600 for installation.
LOL! One THOUSAND DOLLARS??#$@#
what price would u say that would be decent?? installed for the compustar?
Originally Posted by XxAfG786xX
my friend installs them for 200 bux, nothern virginia region....
Thanks,
2007 NBP TL
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
After researching and not finding too much information, on remote starts in an '07 Type-S i decided to just go with the Remote Started i had my eye on. I got the Python 950 (2 way pager By DEI) installed last week. The price was $315 for the unit, $75 for the bypass (no key was lost), $165 for installation, coming to a total of about $585 including tax. It was a bit expensive, but it turned out awesome. Very nice to get off work and have a nice warm seat even in the middle of a Chicago winter!
For those in the area, i went to Abt Electronics in Glenview. Pretty much all of their mobile electronics people are knowledgable. And, they like to negotiate the prices...
MetalGearTypeS
08-29-2016 08:28 PM
SinCityTLX
10-07-2015 01:24 PM
