'07/'08 OEM camera w/license plate frame installed in '05 TL
05tl and 07/08tl frames side by side
noticed that both frames fit perfectly with the exception of the two top holes
i ordered SUB-WIRE, CAMERA Part Number: 32109-SEP-A00
however the end connector is different and it still requires the green connector
Will look forward to the updates. I found a 2007 TLS camera (and navigation dvd drive + screen + radio) at a local junkyard, and want to install the OEM camera into my 2005 TL. Thanks for posting your progress!
NOTE:this installation was done on a 05 TL with navi and 6spd mt tranny
I ordered the 07/08 NAVI DRIVE w/disc straight thru plug n play to connect since my TL had NAVI already.
Ordered oem cam from a 07 TL from ebay seller, it came with license plate frame as shown on the pics above.
ordered the cam-subwire, but that doesnt connect all the way thru and there is no reference on any acura dealer online for the small section of wire harness needed to finish the hook up, luckly i was able to get the missing connectors with pigtails from kenny416(thanks a lot bro).
I will post some pics of the connectors and the wiring diagram
Can't see the writings on the connectors.
Were you able to get the part #s for the connectors?
Also since you got the 07/08 drive connected to the 04-06 head unit, did you use your old nav codes or it has to have the 07/08 nav codes.
Does the HFL work? or can you add the 07/08 HFL?
Thanks for the write up.
LEFT side connector goes towards the CAM, the RIGHT side connector goes towards NAV unit
no I couldn't find the connectors part#
once you swap the nav unit to a different one then you do need the code for the new nav unit
Yes, my HFL works
Yes, my HFL works
Thanks for your help. Did you try to update the HFL? The green connectors must have some manufacturer number. You'll need a magnify glass to find it.
Osvaldo516, did you get any issues with the touch screen. I have tried the 07/08 drive to the 05 navi screen and the bottom rows seem to be off. It seems that the bottom touch buttons are off two rows. So screen buttons work fine. Some I have to touch under the screen buttons to work.
