Yes, another question about the transmission
Old Aug 24, 2011 | 08:56 AM
jdm_94-07TypeS's Avatar
Quick question, should I change the oil, filter and 3rd and 4th switches at the same times?? or first the switches drive some miles then the oil and filter??
My car already has 111K miles!!! no problem at all but I want to do this for prevention.
Old Aug 24, 2011 | 09:15 AM
erdoc48's Avatar
06 Anthracite TL
All can be changed at the same time- just do the 3x3 drain (see the DIY) and fill and no flushes.
Old Aug 24, 2011 | 09:17 AM
UA6's Avatar
UA6
Old Aug 24, 2011 | 11:17 AM
swoosh's Avatar
takin care of Business in
everything can be changed at the same time but I give my car some time to adjust to the new stuff....couple questions for you:
1> how often have you performed a drain and refill or a flush on the tranny ?
2> are you sticking to the stock fluid or going redline/other aftermarket fluid ?
When you change something on your tranny that has high mileage i recommend "taking your sweeeeet time"....so if the car doesnt like something, you can go back to stock without hurting a thing.....
I would do the following:
112K miles: drain and refill
113K miles: drain and refill + switches
114K miles: drain and refill
115K miles: drain and refill + new filter
so you have done a tranny 4x3 and gotten new switches and filter....
why 4x3 you ask....i usually get 12qts of redline and thought the 3 qts are better off sitting in the tranny than the garage....
Old Aug 24, 2011 | 05:15 PM
Originally Posted by UA6
thanks for your cooperation!
Old Aug 24, 2011 | 05:22 PM
this guy understood my question!!!
this is exactly I was asking because my car has a lot of mileage and I know to much changes in a transmission with this kind of miles could be wrong.
I'm going from OEM fluid to the Redline not sure yet if use the D4 or the racing.
I liked your idea about how/when to change the things. Tahnks so much for your advice.!!
Yikes
May 3, 2021 04:29 PM
pstomps
Feb 20, 2017 03:29 AM
BoricuaTL
Apr 8, 2016 01:08 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
