XM flipping back
XM flipping back
First time posting long time reader. I am having a problem when I change my channels on my XM radio via the steering wheel channel button it sends the XM back to channel 1 (Promo). Anyone have a fix for this? I have already renewed with XM and the problem still exists. Xm said its Acura's problem. Acura said bring it in. Dont really want to send my car to the shop. Thanks
I had the same problem and figured it out. The steering wheel controls only work to switch the XM channels that you have programed into your radio keypad, like you program your local radio stations. The radio can remember both. You can program 12 stations. Press the XM button once for XM-1 and then program 6 stations then press the XM button a second time for XM-2 and then program another 6 stations. The steering wheel control will then cycle through the 6 programed stations in either XM-1 or XM-2. If you don't program the XM stations, the steering wheel controls allways brings up the introductory XM remarks. You can't use the steering wheel controls to cycle through all of the XM stations like you would intuitively think. Hope that helps!
Thanks everyone. Dont know what I was thinking about. I guess I just assumed. Everyone knows what the definition of assume is: as_ out of u and me. Thanks again to everyone that that responded.
Thanks everyone. Dont know what I was thinking about. I guess I just assumed. Everyone knows what the definition of assume is: as_ out of u and me. Thanks again to everyone that had responded.
Originally Posted by caball88
how do you get 12? do you mean XM1 and XM2?
However, I do use the scan feature to check out everything. Does anyone know if there is a way to adjust the scan mode to sit on stations for a bit longer than the 5 seconds or so that is default?
yeah same here i like to surf through the stations but there are too many to just go straight thru. i use the category filtering to narrow it down but it sucks because you have to scroll through the categories and can't jump to a specific one.
I think you can arrange through the XM folks to have entire sets of stations blocked. Thus, if you don't like country music, you could probably ask to have all stations in the country category blocked to try and cut down on the noise.
Personally, I find that 12 presets is just about adequate for me. I put the music stations I listen to frequently on XM1 presets and the news/sports stations on XM2 presets. I've also taken to using the Category mode, so the dial just flips between stations in that genre.
Great one. I thought what it could be...
12 is not enough for me.... I would likeat least 18... but I make do.. I go to one of the presents then scan through that neighborhood.
Category mode's drawback is that using the regular tuning knob, in category mode it ONLY gfoes through one category.. so its an extra step to press the category buttons to change category then use the knob to go through the cateogry.. too much hassle for me.
rockyboy
Aug 4, 2024 10:35 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
