Are xenon lights stock on 06 tl?
hey guys, bought my 2006 tl and paid it off about 6 months ago. it was completely stock. Since this is my first car (I'm 18) I don't know much but so i need some help. The low beam lights on the stock lights arent that bright and the fog lights are a nasty yellow. I want to replace both of them with the brightest lights avaiable. i looked on ebay and there are 2 kinds of 9006 bulbs for the fog lights. one kind are xenon and the other are halogen. Can i just buy a 12000k xenon light to replace the oem yellow bulb? or do i have to buy the HID conversion kit. I have replaced every light in the cabin with a blue bulbs so i want my headlights to be blue
the low beams are HID, but just a little warning about the k rating. the higher k you go, the less useable light you get.
the stock k rating is 4300k, a lot of guys wont go past 6k including me.
as for the fogs, it all depends on the look you wanna go for. do you want two blue HIDs lights coming from the same housing, or do you want to upgrade the halogen bulbs?
06 WDP/Ebony MT NAV ASPEC
hey guys, bought my 2006 tl and paid it off about 6 months ago. it was completely stock. Since this is my first car (I'm 18) I don't know much but so i need some help. The low beam lights on the stock lights arent that bright and the fog lights are a nasty yellow. I want to replace both of them with the brightest lights avaiable. i looked on ebay and there are 2 kinds of 9006 bulbs for the fog lights. one kind are xenon and the other are halogen. Can i just buy a 12000k xenon light to replace the oem yellow bulb? or do i have to buy the HID conversion kit. I have replaced every light in the cabin with a blue bulbs so i want my headlights to be blue ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
alright cool, thanks so much for the info. well i want the brightest lights available for the low beam HIDS, i believe either the 6000k or the 8000k have that blue-ish white tint? and for the fog lights, i want them to match the low beams. What do you recommend?
Also, how do i replace these bulbs? I have some idea but don't want to break anything. instructions for this noob would be great
Also, how do i replace these bulbs? I have some idea but don't want to break anything. instructions for this noob would be great![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
06 tl - best low beam and fog light bulbs?
i am a noob and i bought an 06 tl six months ago. it is completely stock so the mods are coming along. I want to replace the low beams and the fog light bulbs. I was informed that the low beams are HIDs so i want the brightest bulbs available. someone told me the fog lights are halogens and not HIDS so i want them to match the low beams. ! also, how do i replace the bulbs? on my 05 camry, i just twist and give it a lil pull and the bulb popped out. What do i do for an 06 tl?
thanks in advance guys!
not sure how hard it is on the newer tl, but it was pretty easy on mine
Registered Member
The 3G TL does not have low beam or high beam headlamps. What it does have are bi-level lamps and yes, they most certainly are HID (xenon) lamps. What passes for low or high beams is a flap which in its normal position ("low beam") is down. When the driver selects the "high beam" position, the flat is raised. So the lamps are neither low beam nor high beam. It is the flat which does the work.
As for the fogs on the '06, they are NOT HID ("xenon") lamps but rather halogen lamps which means incandescent lamps - i.e., they have a resistance filament. You can buy higher output 9006 lamps to fit the fogs (I have done just this) and get more light. I went with the Philips Premium lamps to get more light output in front of and to the sides of the car. They do a very good job. The new Sylvania SilverStar Ultra lamp looks promising.
BTW, 9006 lamps are not available as HID ("xenon") lamps.
i ran those for over a year before i converted my fogs to HID, very bright light, but just as pricey as the HID kit i bought. silverstars 49/pair, hidextra conversion kit/60
Registered Member
Wow, I didn't know they were that expensive. I haven't seen any yet but then again, I haven't looked for them. I thought I would stop by an auto store tomorrow just to check them out as possibles for my Ford Ranger pickup.
though expensive, i bought a pair for my gfs camry sport because she doesnt like hids. made a world of difference.
theres also standard silverstars for 39/pair
Registered Member
I've tried the standard SilverStars in my wife's former BMW. The Philips Premiums actually put out a little more light. I use the Philips Premiums in my '04 TL fogs and they really do a great job.
![Sure](https://acurazine.com/forums/images/smilies/sure.gif)
anyway, its now converted to 6000K which give bluish white light output.
Registered Member
So thanks again for your getback.
Registered Member
At least that is true for the '04 and '05 models.
Whoaa, thanks for that info. I installed the Philips Premiums in my '04 TL fogs maybe four years ago because I wanted to put as much light as possible on the road and to the sides (we have a lot of wild 4-legged creatures were I live). Up until this past September, I used them every morning on the way to work and I still have the original set.
but under normal use, i highly reccomend the silverstar ultras as an hid alternative. theyre suppose to outlast standard silverstars by 30% or something like that
Registered Member
no prob bro, the main reason why mine go out so quick is that i leave my lights on, so even in the day, my hids/fogs are on. why i do it, i dunno, i just do it merely for looks, but i make a lot of short trips and my lights are always going on and off..guess thats why im having ballast problems. lol fail
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
