Window control through remote
VTEC HoooA
I remember reading that the remote was able to open and close the windows adn sunroof. Can someone confirm that this is the case?
Thanks in advance!
Thanks in advance!
press unlock and hold it down. also if you turn the key and hold it turned it will open all windows/sunroof. and then if you turn it the other way to lock it and hold it, it will close all of them
You cannot close the windows and sunroof with the key fob, only open them. This is a safety thing.
bradjs-thanks for the reminder. I had read in the manual about the key in the lock closing them all but I forgot it, so I was closing them all individually instead of using the key in the lock to do it all at one time.
Does anyone remember when power windows first came out, if you tried to work two windows at the same time the fuse would blow? We've come a long way since then. Now you can do 4 windows and a sunroof. Wow.
SinCityTLX
10-07-2015 01:24 PM
xsilverhawkx
09-28-2015 06:51 PM
