Window Auto Up/Auto Down not working
Hi All,
It appears that my battery was drained last night somehow (must have left the door ajar). When I went to the car this morning, the car obviously didn't start right away. I gave it a few minutes and I got it to start.
I'm not sure if this has anything to do with it but now my driver side window auto UP/DOWN doesn't work.
The passenger side works fine
Any ideas?
Any ideas?
Don't feed the...WTF?
I wish I had more of a detailed answer for you, but since nobody else is chiming up - I'll give you a start.
Somewhere there is a thread about resetting the stop points for the auto up/down. Some people have had issues after getting tint, or replacing parts. I'm sure if you do a search, you will be able to find it unless someone else knows where this is.
I think this is what you need to do... I just don't know how to do it at the moment.
maybe u were cleaning the car and it got moist inside. its probably shorting out.... happens to me a lot of times after i detail it inside but then once it dries out it starts working again normaly
TL-S izdashiznittt in
1 Post
Ive had the same problem with my car. There is a way to fix it temporarly by holding it down for a certain amount of time or somthing like that. Take it to the dealership and they will let you know. But to permanently fix the problem, they need to change out the regulator in the door. Which is going to cost them like 400 dollaz. Hope this helps, but ya take it to a dealer and MAKE them realize that the regulator is broken and that it needs to be changed.
TLDude876
12-28-2016 03:18 PM
ahsm
09-09-2015 08:35 AM
asahrts
09-04-2015 05:55 PM
