Why does MT use FM Synchromesh but ATF Redline NO FM?
I bet you can learn a lot from reading these threads.
https://acurazine.com/forums/3g-tl-2004-2008-93/amsoil-synthetic-transmission-fluid-vs-redline-d4-atf-776213/
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/racing-atf-764322/
specifically read "I hate cars" and "inaccurate"s post
Other forums don't mean a thing when it comes to what we use in the TL. I've spent countless hours going over the technical side of this in other threads and I honestly don't feel like doing it all over again. It's out there, just search.
The end result is a non FM fluid cures shudder in the TL, much less create it.
It shows much less wear as is evidenced on the drain plug.
Shift quality is much better than stock.
Shifts are much quicker than stock.
The current turbo TL has never had a trans failure on this fluid while the first turbo TL failed within a day on Z1.
It's all on here and with so many people doing this and all with the same positive results there is no debate. The end results speaks for itself.
but the info is already here. you just need to dig through it
For what its worth, Matt used to be a transmission re-builder.
vpasla1
09-17-2016 07:24 PM
EvilVirus
12-10-2015 07:38 PM
