White Smoke from A/C Vents
Old Sep 29, 2015 | 08:23 PM
OsK's Avatar
OsK
Earlier this month, it was 105 degrees and I was driving for >2 hours straight, A/C was on the whole time. After two hours, cold smoke was coming through the vents and I freaked out a bit. But, it went away after 30 seconds.
Is this just normal condensation due to outside conditions (humidity?)? I didn't have recycle air turned on.
I'm just curious and wondering if I should be worried. Thanks.
Old Sep 29, 2015 | 08:28 PM
MarcDavidoff's Avatar
I've had that happen before in various Hondas. Believe it is a humidity thing and normal
Old Sep 29, 2015 | 08:45 PM
Jboat's Avatar
I've had the same thing happen before. The kids thought it was pretty cool...pun intended.
Old Sep 30, 2015 | 01:02 AM
eastcoastguy's Avatar
Mine does this, however, its not smoke its just condensation. It could just be the humidity or it can be the start of the evaporator freezing over.
Old Sep 30, 2015 | 09:41 AM
ggesq's Avatar
^ that's what I was thinking too. Evaporator problem. I had mine recently replaced and I could see the air coming in through the vents.
Tech at the dealer said it was normal
Old Sep 30, 2015 | 12:15 PM
ExcelerateRep's Avatar
Former Sponsor
It happens due to the contrast between the humidity outside and the dry air coming from your AC. Just means your AC is working great!
Old Oct 1, 2015 | 02:45 PM
mazen222's Avatar
I had this on my old car (99 Solara). The problem was the blower fan was not working on speed 1 and 2, but was ok on speed 3 and 4. Which caused ice condensation when it was on 1-2 since no air was flowing, then when it hit 3 i get the white "smoke".
Turned out to be a burnt fuse.
Check if your fan works on all speed to be sure, if it does then you're ok.
Old Oct 1, 2015 | 02:51 PM
maharajamd's Avatar
I was always told, and maybe this is an old and outdated way to go about it, to run your fans but turn the AC off for the last 5 minutes of your drive to clear out the humidity/condensation...
Old Oct 1, 2015 | 02:55 PM
polobunny's Avatar
Registered Bunny
Still very valid and good tip, otherwise you might end up with a smelly AC.
Old Oct 1, 2015 | 02:57 PM
maharajamd's Avatar
Biggie_B
May 27, 2025 05:51 PM
rcs86
Aug 2, 2016 06:52 PM
JDM96specCTR
Oct 17, 2015 01:06 PM
johnpancakes014
Sep 27, 2015 12:58 PM
Rcelestino93
Sep 23, 2015 10:01 PM
