White Needles on TL Speedo
I hope that I am putting this in the right spot. I returned my TL after 22 hours of ownership because I could not read the guages, speedo in the afternoon glare. Anyone know of a way to mod or change the needles to white? I loved the car but need to have white needles. It a "can't see red on Black very well" sort of thing and I completely lose the needles in bright daylight even with MAX brightness.
Help please.
Help please.
i think you just may have to change the bulb that illumates the needle
Thanks for the replies. Yes, a little red on black color blind. The dealer called and suggested that they could paint or tape the needle white. Then asked if that would leave the needle Dark.Black / no light at night. The response was "Oh". I am wondering what would happen if they just painted or taped a portion of the needle white. I would see the white portion when the glare is bad and the red the rest of the time. Problem is that I am not taking the car unless I have a solution that will work. I don't want a new car with a botched speedo. Thanks again, Keep brainstorming.
2004 SSM/EB/5AT/Navi/RSB
I think the best thing for you would be if they could somehow put in a clear needle with a white LED illuminating it. As you said, the only thing that makes the needle visible is that it is lit from inside. Painting it white or applying tape would make it invisible at night.
I wonder if it would glow a different color under black light. UV LEDs are available.
Since the issue is color blindness in specific colors, I wonder if they put a different color LED in to illuminate the red needle (Green, Blue, etc), if that will change the hue or color of the red plastic needle enough to take it out of the color range you are blind to?
If you dont know what I mean, put a blue light in a yellow turn signal lens cover and the color that shows will be green. Some thing like that but with the needle.
How can you call the speedo botched when the problem is your color blindness?
I'm surprised the dealer took back the car, since there is nothing wrong with the car.
Sounds to me like you found a good dealer, if they are willing to work this hard for your business.
Youse Gots Sacked
Originally Posted by chfields
I'm wondering, didn't you notice this when you took the test drive?
![Stupid](https://acurazine.com/forums/images/smilies/imwithstupid.gif)
Not sure if you got it. I said that the issue is me, not the car. I said that my test drives were in the evening (after work). When I mentioned botched speedo I meant if the dealer made an attempt at addressing my issue and it did not work and or had an adverse affect and I had agreed to keep the car prior to the attempt. You are right, Gunn Acura in San Antonio is willing to go the extra mile. Nonetheless, I appreciate the feedback.
I did misunderstand some of it and I do apologize if I offended you in any way.....
Registered but harmless
Received 1,107 Likes
Other possibility- getting a digital add-on accessory like a G-force meter or add-on gauge cluster? There are several different types of performance meters which have digital speed readout (but won't tell you fuel level, RPM, etc.) for about $150+ that don't require altered wiring, or the old school add-on gauges which are more permanent and require hard wiring.
Going with the different color needle idea, you could see if the Accord's needle fits the TL. With some luck, it could be an easy swap.
If not, write to the Acura directly and see if they have a way of accomodating your handicap.
On a sidenote, this "afternoon glare," are you referring the the cluster glass? If so, you could see if tinting it with glare-reducing (clear, obviously) film could help.
Grerat feedback / ideas. By afternoon glare I guess I really mean when it is so bright outside the car like in mid to late afternoon. I see red fine when there isn't too much extreme sunshine competing with it. I asked the Acura dealer about the white Accord needles and he said that he would get back to me. As for someones idea about a digital speedo, that would be nice but I wouldn't want to make extreme changes on the car when it is brand new.
I think that I am just going to give up on the TL for now and probably will wait a bit to start shopping again. The Lexus IS looks interesting and I think that it has white needles. Thanks again to everyone for their input.
King of NYC
Well the colored LEDs to combine primary colors to get a secondary colors seems like a good idea......If you changed/wired a blue LED in you'd might make purple? Or try a yellow LED and get orange. The only sure fire way is to get a gauge cluster and experiment. I think I saw one on Ebay yesterday. The design of these gauges follow in the old Prelude's design of being backlit at all times, so painting the needles will make them opaque cutting down light output. You want them bright and visible.
Why not change the gauge face? There are a large number of aftermarket companys that make basically stickers that can changes the faces to anything you want. Would red on white be easier to read?
So much positive support and input. Thank you. I think I like the idea of a sticker on the guage face. Maybe a White circle about an inch out from the post. The dealer is willing to install "tape" on the needle, like a 3/4 inch segment about a quarter inch from the post. I am going to call the dealer back this morning and see if the car is still there and go pick it up. I looked around and there just isn't another car out there with the same content at the same price point. Now I just need to figure out if I should have the dealership make the mod or attempt it myself. If I have the dealership do it the pro is that they know how to take the dash/cluster apart. The con is that I have less control and can't try different solutions. The pro of doing it myself is trying to figure out how to dismantle the cluster. The pro is more3 control and ability to try several different solutions. The con is my taking the cluster apart. Anyone have instructions / diagrams on how to dismantle the cluster / dash?
Registered User
the cluster comes apart in a matter of minutes, the bezel pulls out(attached with clips) and the cluster is held in by 4 screws.
here is when i pulled my TL cluster apart
http://rbf351.com/rob/main.php?g2_itemId=7891
Originally Posted by BrandonClaps
how do you stop at red lights? :curious george:
Outstanding! I will follow the link. I am pretty handy so it sounds like this is something to take care of myself rather than have the dealer do. Thanks again.
I think the background circle idea is the only real solution so far. If I'm not mistaken, putting a blue LED behind the red plastic needle will not give you purple. While red and blue combine to make purple when adding pigments, the red plastic needle will filter all but red light from the LED's output. Since there isn't any red in a blue LEDs glow, it may just be very dark red in the end.
Registered User
also removing the needles is a bitch to do without breaking them.
acura-cl.com OG
actually if you change the red led's to blye ,you will have no light at all on the needles.
Registered User
Originally Posted by ding069
what did you mod in your gauges? why did you take them apart like that?
Don't jive my 3.5
Help please.
Help please.
Originally Posted by Acuraboy7
well you took it back already, what good would it do now?
