when should i change the Fuel filter and how to?
Old Dec 29, 2009 | 10:53 PM
deepblue626's Avatar
when should i change the Fuel filter and how to? thank you
Old Dec 30, 2009 | 01:05 AM
Hapa DC5's Avatar
אני עומד עם ישראל
there is no traditional filter. to my knowledge there is only a screen which is located in the tank with the fuel pump. it should only be changed if there is a problem with the pump, other than using top quality gas there isn't much maintenance you should do with it. you may want to use a product called sea foam to clean up the fuel system, that is up to you.
datadr
Sep 12, 2015 09:12 PM
Aleax
Sep 11, 2015 11:31 AM
sputik
Sep 7, 2015 01:40 PM
NSolace
Sep 3, 2015 08:14 PM
bymotion
Aug 31, 2015 05:00 PM
