when push the brake is all 4 brake use to brake or just the frount 2?
Old 09-21-2009, 09:13 PM
deepblue626's Avatar
i got an 05 TL.
deepblue626 is offline
Old 09-21-2009, 09:18 PM
Yvuru's Avatar
When you push on the brake all 4 corners are braking but the front does most/more braking.
Yvuru is offline
Old 09-21-2009, 09:24 PM
thank you. i did replce my front brake pad and cut the front rotor now when i brake still feel put unnormal should i cut the the rear 2 rotor also?
Old 09-21-2009, 09:33 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
No need to post the same question in two forums.
https://acurazine.com/forums/3g-tl-problems-fixes-114/when-push-brake-all-4-brake-use-brake-just-frount-2-a-745244/
Bearcat94 is offline
Old 09-23-2009, 09:10 AM
LoveMyTL-S's Avatar
I'd say if your going to do brakes, do all 4 at the same time. Same with rotors. That way you get a more even braking power and no mismatching. So, right now you have new pads on the front and worn pads on the rear. With the fronts doing most of the braking anyway, it's going to feel more toward the front than rear, but more so with worn brakes in the rear. The brakes should still work fine like it is.
LoveMyTL-S is offline
SidhuSaaB
05-30-2020 12:40 AM
blacktsxwagon
10-27-2015 10:12 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
Quick Reply: when push the brake is all 4 brake use to brake or just the frount 2?
