When to do Timing Belt - Interference Motor?
I have around 84k miles on my 04 acura tl 6 speed.
Wondering when I should do the timing belt and what other service is needed around this mileage?
What if the timing belt were to break would it damage the engine?
Also how long are you guys going before oil changes? And are you using synthetic oil only?
Thank you.
Thank you.
If you do a quick search here you should find the answers. But generally you want to do the timing belt at 105k.
Also you will want to do the water pump (wholesalepartsguy here has a good package special to help you save money on the parts), tensioner pulley, and probably the spark plugs. It is also debatable but some people like to go ahead and have the valves adjusted at 100-105k especially if they're going to keep the car for a while.
Edit: Even with good synthetic oil (most people here recommend Amsoil 5w30 or Redline 5w30...they're both great oils) I have found through mail-off oil analysis that the MID is pretty much dead on for when your oil needs to be changed. For me it's generally around 5500-5700 miles.
TQ > MPG
Well I have 144k and havent done it yet, but thats more out of laziness and stupidity than great knowledge. lol
I'd call around to some reputable import shops, as they'll be less expensive than the dealership and prob do a better job.
is this a non interference motor?
If you dont do it will it damage the engine if the timing belt breaks?
What has it cost you guys to do the timing belt and water pump?
Registered Member
Things to have done when it's time for a timing belt replacement (105K miles);
- Water pump.
- Any pulleys/tensioners in questionable condition.
- Serpentine belt.
- Hoses.
- Spark plugs.
- Valves adjusted, if needed.
- All fluids, if not already changed, such as brake fluid, clutch fluid, power steering fluid.
- Have your A/C system checked out.
There are more items to be checked/fixed/replaced. One of the member recently posted a list of them so do a search and if you find it, please post the link for others.
Thank you.
Thank you.
Registered Member
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
