Wheels For My TL
Wheels For My TL
Hello All,
I just purchased axis Hagen’s (color black shadow) for my new 04 anthracite Tl with the eibach lowering kit. The wheels are 19x8 front and rear. Tire sizes are as follows front 235/35/19 rear 245/35/19. Here is a picture of the wheel I just purchased in silver let me know what you guys think.
6G TLX-S
Originally posted by bustedbyu
Why 235 in front and 245 in back?
With different size tires front and rear, you won't be able to rotate them. Well you could I guess but what's the point. Anyway, expect to go through a small fortune in tires for the front.
The difference in overall tire diameters could create problems with the functioning of your abs/traction/stability control system depending on how sensitive the system is to different wheel rotational speeds.Hopefully this wont be a problem.
These tires have the same inner diamater (19), and the same outer diamter tire (35).
The only difference is the width of the tire with the rear tires 10mm (just under half an inch) wider.
These tires should all rotate at the same speed as their diamater/circumference is the same.
'06 750Li Sapphire/Creme
HaHaHa...Ho Ho, Ho
Guys, guys, guys..This guy is OBVIOUSLY planning on placing the larger tires on the FRONT of the car. You know, the "frog" look is coming back into style. Sorry bud, but you REALLY do not want to do the stagger thing with this front wheel drive car. Besides making it handle poorly, it simply would look wrong to those of us who understand the form/function of the staggered tire system...
JByron
01-08-2016 09:49 PM
