Whats wrong with your car?
Old 03-08-2011, 01:41 AM
kirill1221's Avatar
Hey guys, I'm bored so I decided to make a thread where we list the various things that are wrong with our cars. Maybe if we all compile our own list it will motivate us to get those issues taken care of quicker.
Ill start:
1. Fix steering wheel volume control lights. They're out.
2. Fix the light that turns on when the drivers side seat heater turns on HI.
3. prevent the drivers side door cubby from sagging/opening up randomly.
4. Replace one screw that connects radio to HVAC unit that I forgot to put back.
5. Clean up engine bay.
6. Clean up interior.
Lets see some of your lists. Hopefully yours isn't as long as mine haha
Old 03-08-2011, 02:01 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
1. navi voice pop (https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/navi-voice-809099/)
2. auto tensioner bearing going bad(new part coming in few days)
3. drivers window creaks when fully shut, passenger window too but only during hot days and not as bad as drivers side.
4. flaking door handles(new handles coming in few days)
Old 03-08-2011, 03:33 AM
Make it so
DuoDSG's Avatar
Thumbs up
1. Replace the bulb that lights up the emergency flashers light
2. Replace lights in seat heater switches
3. Put replace some of the clips that hold the interior panels on
4. Replace driver's side door molding (the one on the floor) piping
5. Tweak the driver's side mirror motor so it has some lube
6. Replace some random screws and clips around the glove box, as well as those around the bumpers (a lot are chipped thanks to road debris over the years)
and lastly...
7. Figure out how my navi voice works again. This isn't something bad or wrong, per-se, but I have a 2004 TL with navi and I had to replace my head unit with one from a 2005. That change killed my ability to hear the navi's voice or to use the voice command function. And as of about three weeks ago, it works perfectly.
The reason that doesn't make sense (why it shouldn't work) is because Alpine changed the placement of two wires between 04 and 05, and therefore the navi voice shouldn't play through the speakers. But thanks to divine intervention, I can hear the voice and give commands again. Halleluiah.
Old 03-08-2011, 04:13 AM
SpiderX1016's Avatar
1. Rear Deck Rattle.
2. Trunk Rattle.
3. Scratches from someone rear ending me.
Old 03-08-2011, 04:52 AM
Get Money
stiffdogg06's Avatar
- Left front tweeter rattle
- Rear shelf rattle
- Front dome light area rattle
- Replace some of the push clips for the bumpers that were snapped
Old 03-08-2011, 06:41 AM
edmua6's Avatar
1. Steering wheel lights out.
That's all i know.
Old 03-08-2011, 07:14 AM
flyromeo3's Avatar
1. replace Heater Control Valve
2. change atf
3. replace interior speakers (stock one seems to weak )
4. get all season mats ( not sure with weathertech digital )
5. hardwire my dash cam above rear view mirror
6. tighten bolt that holds heatshield - its making a slight metal clanking noise ---one of those noises apparently I only hear, as my friends & wife state
---i think thats it for now. I'm sure ill find something else on my drive back home this afternoon.
Old 03-08-2011, 07:28 AM
Received 16,263 Likes on 11,973 Posts
1. needs moar torque
2. WRONG wheel Drive.
Old 03-08-2011, 09:11 AM
KN_TL's Avatar
It's in my unheated garage with 2 ft of fresh snow outside.
I don't have all my parts.
I have Tein SS/EDFC and RV6 strut brace sitting in the basement
I have 4 A-Spec wheels in the basement with no tires.
Old 03-08-2011, 09:15 AM
veggiemonster's Avatar
yep.
Old 03-08-2011, 09:40 AM
2007 TL Type-S NBP
jpgayan's Avatar
More squeaks and rattles than a day care center full of mice!
Old 03-08-2011, 09:58 AM
Registered 3.5L Member
BigPZ's Avatar
1. Secure the bottom of the license plate with two more bolts to stop the annoying rattling
2. Give her a good spring interior cleaning to get all the salt out of the carpets, and a thorough exterior wash/wax as soon as the snow finally f@%ks off
Old 03-08-2011, 10:13 AM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
- got a few rattles
- Maint coming due (oil, rotation, trans fluid/sensors)
- spring detail
- couple of self-inflicted dings
- might need tires this year
- trunk LED flickering
Old 03-08-2011, 10:32 AM
RAR
leedogg's Avatar
Received 1,286 Likes on 714 Posts
Do you use a license plate frame? Sometimes, people dont have the bottom of the plate securely mounted inside the frame and therefor it rattles away.
Most of my steering wheel lights just went out
Old 03-08-2011, 10:45 AM
drivinginmy04tl's Avatar
Yes my steering wheel lights had gone out as well. For anyone with bulbs out especially in the steering wheel or HVAC and Navigation buttons might I suggest replacing them all instead of just the burnt out ones. I learned the hard way was not thinking and only ordered burnt out ones. I later went back and replaced all. For instance when doing HVAC bulbs might as well order the Navigation menu ones because they will go out and it is such a pita to go back through removing everything.
Old 03-08-2011, 10:50 AM
RAR
leedogg's Avatar
Yeah, i've been meaning to track down that diy that lists all the bulbs and steps. Plus you want them to all be the same color.
Old 03-08-2011, 10:56 AM
Yes I learned that to. I am in the Chantilly Va and see your in the area so if you have any questions or run into trouble feel free to ask me leedog. I have replaced all of them except the overhead console sunroof button and door window and locks but I believe those are not replaceable without sodering. I also have a friend at a local dealer that can get the bulbs at wholesale pricing so shoot me a pm If you need them. He knows his stuff and can make sure you get the wright ones.
Old 03-08-2011, 03:04 PM
the overexplainer
ez12a's Avatar
2 spots bird poo etching damage about the size of my thumb print on my roof.
Pretty much it. Just waiting for 60k to come around to get my front brakes done.
Old 03-08-2011, 03:05 PM
^why wait for 60k?
my pads were gone at 40k.
my rotors still had lots of life left, but i changed them out to slotted.
Old 03-08-2011, 03:17 PM
the overexplainer
ez12a's Avatar
It would fall nicely in line with my next oil change. I work in San Diego county but the only shops i'd trust to are up in LA.
They said I had about 20% brake pad life left when I had it inspected at 51k. I do a lot of highway commuting so I could drive 100 miles a day and barely touch the brakes. That and I just dropped about $500 the other weekend replacing tires, getting an alignment done, flushing brake fluid, and changing MT fluid to GM FM.
Old 03-08-2011, 03:34 PM
lazytik's Avatar
Steering control light out, left fender light just started flickering last night, needs new rear rotors and calipers, needs new endlinks, going to do oil and transmission fluid change and replace 3rd and 4th gear pressure switches.
3 slight scratches which I'll work on in a week
126k miles now...getting worried about the transmission but changing fluid and new sensors.
Old 03-08-2011, 03:50 PM
dj5
dj5's Avatar
Absolutely nothing, it's perfect just the way it is.
Old 03-08-2011, 04:04 PM
Deep n TX's Avatar
^Denial
Old 03-08-2011, 05:41 PM
the overexplainer
ez12a's Avatar
why cant i edit my post I forgot, my drivers side front sidemarker is dim/non-working.
Old 03-08-2011, 05:58 PM
2004 SSM FTMFW !!!!
Dat Boi Ralph's Avatar
- Valve adjustment
Old 03-08-2011, 06:22 PM
cucaracha's Avatar
1. drivers window creaks when fully shut.
2. replace rear speakers
3. Passenger side mirror
4. replace trunk switch
Old 03-08-2011, 07:10 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Dying Battery
Acceleration whine
Some interior lights need replacing
Memory Seat Module doesn't save (common on 04)
Console trim on sides all scratched up
Leather looks like crap now all loose and cracked
Passenger window auto function makes window go back down
Paint Chips
Rust here and there
And so on...
Old 03-08-2011, 07:22 PM
3G TL/2G MDX Owner
TLtrigirl's Avatar
-subtle drift to Rt.
-subtle vibration at hwy speeds coming from Rt. front (yes, i've had it aligned, yes, i've had the wheels/tires road force balanced, and i've had the axles replaced) it still does it.
-rock chips
-no garage to park in at home, luckily have garage at work
-squealing rear brakes when backing up
-rattle in dash, driver's door
i think that's all. no car drama this year, that's my goal. let me get through the year with only maintenance stuff, please.
Old 03-08-2011, 07:31 PM
lazytik's Avatar
No one said transmission yet? lol
Old 03-08-2011, 07:47 PM
GCSIMON's Avatar
-Heated Seat button light out (drivers side)
-Plastic black mesh in rear bumper smashed in (Damn snow banks)
-Need new brake pads eventually and new front tires
-Not enough mods
Old 03-08-2011, 08:13 PM
rebelangel's Avatar
-headlights hazy on the inside
-driver side mirror clicks when the reverse is activated. I keep the switch off since I don't parallel park, so no biggie
-rear tires worn, front tires aren't new
-slight paint overspray on passengers side of windshield, but no chipped paint at all on the car and no frame damage or other indication of accident, yet no report/carfax of paint job
-window tint removed (who does that??? It was a dealer job on the carfax. Bad tint job I guess.) Needs tint! LOL
No rattles, no lights out, no issues with seat memory or blue tooth. Overall, the tires are my only $$ issue, the rest is cosmetic and minor. Windshield is easily fixed with a razor blade, side mirror no biggie if I don't fix it. It's garage parked weekdays, so tint not THAT big of an issue. I would like clear headlights though!!!
Old 03-08-2011, 09:12 PM
'06 TL 5AT NAV Anthracite
WayneJay's Avatar
4 light bulbs out (2 on steering wheel & 2 on dash). Scratch on the hood, a few paint chips from rocks and a crappy tint job.
Old 03-08-2011, 09:31 PM
shellready's Avatar
1. scratched the paint off the door when I swung my door open and hit my fiance's side view mirror
2. bulb is out for the heated seat on the drivers side
3. nav drive needs to be replaced
4. car is not paid for
Old 03-08-2011, 10:21 PM
vietxquangstah's Avatar
1. my sunroof ONE-TOUCH OPEN/CLOSE and TILT feature doesn't work.
anyone might have a clue why?
i can open and close it, but when i press it to the second click and let go it just stops. same when i try to press the button inwards (to tilt it while the sunroof is completely closed) it doesn't do anything at all.
i know i'm getting a bit off topic sorry.
Old 03-09-2011, 12:25 AM
Former Whiner
Souljah's Avatar
1) Lights out on heated seat selector
2) Lights out on steering wheel
3) Too sexy
Old 03-09-2011, 12:27 AM
Former Whiner
Souljah's Avatar
You're actually pushing it upward, as in towards the sky? Not up and down (towards front windshield to back windshield). I won't even lie... I didn't know that for a while.
Old 03-09-2011, 05:37 AM
Registered TL Owner
pnoi521's Avatar
1. Drivers window rattle
2. Moonroof button backlight is out
3. Rattle from driver's visor
4. Front left damage from being T-boned
5. Rear bumper damage from a parking lot hit and run
6. Rear right quarter panel damage from backing into my friends TL
7. Backlight for trunk button is out
8. Rattle from left B pillar
9. Occasional rattle from passenger's map pocket from bass
10. Passenger's mirror clicks when tilting down in reverse
My transmission went out with > 300 miles on the odo
Hah, I just taught my mom about this feature on her car on Sunday.
Old 03-09-2011, 06:00 AM
Pharonocon's Avatar
1. Rattles all over the fricken place
2. alignment way off after hitting something on freeway.
3. switch from Z1 to redline D4
4. rear bumper scratches
5. Seat heater bulbs
6. Move the hell out of rainy Portland so I can keep my car clean
Old 03-09-2011, 06:49 AM
Stillmatic29's Avatar
1. Drivers side fog light glass cracked.
2. Small paint chip on the hood.
3. Drivers side door unlock switch needs replacement. (locks, but won't unlock).
4. Seat heater bulbs out.
5. Memory seat bulb out.
Old 03-09-2011, 06:55 AM
3G TL/2G MDX Owner
TLtrigirl's Avatar
to add to my list of what is "wrong" with my car-
-my bluetooth cuts out intermittently when making or receiving calls when the phone is compatible....grrrr.
-side mirrors do not return and click when actually used in reverse. so i dont' use them and keep them turned off.
-and of course there are a few spots on the car that have cosmetic flaws that only i notice.
Quick Reply: Whats wrong with your car?
