What's the 'best' white LED interior lights at the moment?
[Mod Censored Title]
redoing my interior lighting from blue to white...i'm too old to have blue interior lights in my car...my at least. what's the consensus on the best white LED interior lights?
and don't tell me to 'search for it'...blah blah blah
I went with the package that JDMtoy sells. Had bulbs for doors, front and rear domes. Pretty bright. It was the SMT rated package. Also if you haven't already you should get the white LEDs for your license plate.
takin care of Business in
Received 4,732 Likes
are you looking for brightness or color ?
I would go with autoluminations 194 bulbs....they are bright as hell and not too expensive...
http://autolumination.com/194.htm
https://acurazine.com/forums/3g-tl-photograph-gallery-96/some-led-love-lots-pictures-810519/
Can't be more satisfied =)
I know a few people that run the EXACT same setup so I call it the "ultimate" LOL
https://acurazine.com/forums/showthread.php?t=810519
if you are looking for subtle, you can save money and buy from superbrightleds...they are not overbearing but at the same time pretty bright and cheap
I would stray away from the LED board as they can be overpowering....
check these out:
http://www.superbrightleds.com/cgi-b...ini-wedge.html
look for the 921x12....they have 12 small LED's (NOT SMT) so they are plenty bright and yet subtle...I put the x12's in the doors/trunk and put x9's in the map/dome....
plus they are only 3-4 bucks a pop as compared to 7.99 or 8.99
check these out:
Anyone nice enough to post DIY links for domes and license plate? You'll have my eternal gratitude (not that's it's worth much off of Azine).
As for the license plate, remove the trunk liner by popping off all the clips, 1 screw, and 2 rubber things that slide in a direction.
Then after the trunk liner is off, you can replace the lights.
EagleEye (08-12-2011)
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
handsom-hustla
11-13-2015 05:04 PM
