What should i replace at 105k service?
im about to change my timing belt, water pump, spark plugs, coolant, transmission fluid...umm is there anything else that should be replace at 105k... like seals or other belts?
Don't forget that the 04-06 TL odometers are off by 5%, so you don't reach 105K "actual" miles until the ODO reads 110,250...
All warranties for these model years were extended by 5% per the lawsuit settled with Honda/Acura...
Just pick up an entire kit, they go for about $300.
http://www.partsgeek.com/catalog/200..._belt_kit.html
I just bought a bunch of parts for my complete tune-up. supposedly at 105k but im doing mine at 98k. My car is showing signs of needing a tuneup bad like vibrating, low on mpg, smells and sounds funny sometimes.... Im doing it this weekend and i'll post up how it feels after the tune-up. exciteddd yo !
https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-105k-service-timing-belt-water-pump-spark-plugs-thermostat-%2Apics%2A-784622/
Have fun! Are you doing a valve adjustment as well?
Dogmatic Dinosaur
I would do the cam and front main seals too if you plan on keeping your car. Although it seems that they are more than capable of lasting 105K, who knows if they will all last to 210K. I fear that a lot of members will be putting the 2nd timing belt on early because of some oil leaks.
I was debating whether i should do valve adjustment, would you guys recommend that too ? how long is the process ? . oh and yea im doing cam and main seals also.
If you've never done a valve job before, I'd say allow 3-4 hours start to finish if you're doing it all alone. You'll also want to consider replacing the intake manifold gaskets (I totally missed these and didn't order new gaskets. I reused the old gaskets and everything is fine. SM says to replace them...), the valve cover gaskets and spark plug seals (mine were pristine, so I didn't)
FYI at autozone you can get the plugs for 10 dollar each!
mada51589
05-03-2022 08:54 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
