What is that pull handle inside the trunk...?
Old Nov 12, 2006 | 12:27 PM
TLova's Avatar
Question What is that pull handle inside the trunk...?
I am sorry to ask silly question...!
Does anybody know the function of the pull handle underneath the subwoofer?
Old Nov 12, 2006 | 12:32 PM
Trackruner228's Avatar
If it is the one that glows in the dark thats there just in case you get locked in your trunk since a lot of people have died that way.
Old Nov 12, 2006 | 12:35 PM
TLova's Avatar
no not the trunk release button....this is located right under the SUB
Old Nov 12, 2006 | 12:48 PM
subinf's Avatar
One on the right for me
so you can open the trunk from the back seat?
Old Nov 12, 2006 | 12:52 PM
chfields's Avatar
I think it is so you can put the back seats down from the trunk area.
Old Nov 12, 2006 | 12:53 PM
bhelsdon's Avatar
it is there so you can open the trunk in the event of an electrical failure. You may have also noticed there is no key hole on the outside of the trunk lid.
Old Nov 12, 2006 | 12:54 PM
bhelsdon's Avatar
The back seats don't fold down in the TL.
Old Nov 12, 2006 | 01:04 PM
TLova's Avatar
Its NOT Trunk release button.....!
Trunk release button = located on the back side of the trunk lid...neon color push button
mystery pull handle = right under subwoofer...roof of the inner trunk
Old Nov 12, 2006 | 01:09 PM
bhelsdon's Avatar
IT IS A TRUNK REALESE LEVER!!!!!! it is black and NOT green and it opens trunk
Old Nov 12, 2006 | 01:11 PM
subinf's Avatar
have you pulled the handle to see what it does?
Old Nov 12, 2006 | 01:12 PM
bhelsdon's Avatar
if you open the pass thru to the trunk and stick your arm thru and pull the "mystery" lever the trunk will open.
Old Nov 12, 2006 | 01:13 PM
csmeance's Avatar
Right under the sub is a handle in case of an electrical failure or in case of an accident.
The one on the trunk lid itself is incase someone gets stuffed into the trunk so they can get themslves out.
Another black plastic one on the edge of the trunk lid is so you can close it with your hands if they are dirty so you don't damage the paint.
Old Nov 12, 2006 | 01:14 PM
jupitersolo's Avatar
nnInn
That's the ejection lever. Don't want to pull that!
Old Nov 12, 2006 | 01:16 PM
subinf's Avatar
I know what the handle does. If the OP actually sees that it opens the trunk then everything will be solved.
Old Nov 12, 2006 | 01:18 PM
TLova's Avatar
Got it....so it works like double safety feature…!
Thanks for the tip…!
Old Nov 12, 2006 | 01:22 PM
chrissix's Avatar
SFC, US ARMY AVIATION
Read your Owners Manual!!!
Old Nov 12, 2006 | 02:09 PM
Neorick's Avatar
It is the pressure release valve. When you exert to much gas from driving too fast...the gas can accumulate and the air pressure from the inside could build up...so that is to release the FART Gas
Old Nov 12, 2006 | 03:46 PM
Ron A's Avatar
Administrator
No, that is the one in the deck lid near the place you grab to close the trunk. The one he is talking about is in the pass-through and as said in the intelligent replies (not to be confused with the other replies that weren't) if you pull it the trunk will open even if your battery is dead or disconnected.
SidhuSaaB
May 30, 2020 12:40 AM
Skirmich
Oct 1, 2015 12:59 PM
ROWDY621
Sep 30, 2015 03:20 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
