What milage to change plugs on my TLS
I'm sure there is a DIY out there but IMO its pretty easy, I believe the plugs are rated for 105k or 90k can't remember off hand. I think the Hardest part about changing the plugs is reaching the back ones but even then it's not bad just take it slow and recheck yourself along the way.
Edit: did a quick search and came up with a DIY for the 2gen's it's the same for the most part. Only thing I did different was I took off the strut tower bar, which isnt really needed but does make it easier to reach the rear plugs.
https://acurazine.com/forums/2g-tl-1999-2003-98/spark-plug-replace-change-diy-760163/
Google is your friend
the plugs on your TL-S won't be due until 105k miles so you got plenty of room left before you get worry.
AZ Community Team
Received 7,770 Likes
This tip from the linked 2G thread is REALLY useful to get that one closest to the passenger seat (right rear plug) out:
in order to remove the spark plug, i and 01tl4tl suggest to first combine the 3"extension and the spark plug socket and drop it in and then attach the 3/4 ratchet and 6" extension to undo the spark plug. it will take some time but you will get the hang of removing it. ....
I just changed mine today at 73K miles. Those OEM NGK IR plugs are EXPENSIVE!! All six cost me $77. It's all good though because I don't have to worry about it for a long time. They were pretty easy to replace. The only thing you have to do is remove the strut bar in order get the back plugs out. Also be careful with the plug coil. Don't get them damage or bent because those thing are expensive just for one. You are looking at close around $150 - $200 each.
the overexplainer
buy them from Advance Auto next time, I got my set for around $55 shipped.
To the OP, i would just wait till 105k. It's not like your plugs will foul themselves from nonuse.
I changed the ones on my TLS a few months ago at 70,000 miles. I was lucky I did because the front center plug was nearly all the way backed out, had never been touched & just loosened up from the factory. I wouldn't change them until 105,000 miles but at 50,000 I would just check them for tightness. BTW I had a honda Tech change them for cash on the side. If I did it I know I'd strip something.
I changed mine at about 75K. I would say between 75K and 100K would be fine. I did mine early because I had the time and the cash for the plugs. It was just after I bought the car and I wanted to basically start fresh.
