What is an good spark plug for '05 TL?
Old Jan 6, 2010 | 02:27 PM
deepblue626's Avatar
what is an good spark plug for 05 TL
Old Jan 6, 2010 | 05:38 PM
RJNN TL's Avatar
Ryan's loving his ATLP TL
I use Denzo Platinum. http://densott.com/
Old Jan 6, 2010 | 05:39 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
OEM. Go NGK. They're the best plug for our cars.
Old Jan 6, 2010 | 05:45 PM
lilsid112's Avatar
+1 cant go wrong with NGK
Old Jan 6, 2010 | 06:55 PM
NAiL05's Avatar
OEM NGK...Buy them at oreillys its cheaper.
Old Jan 6, 2010 | 07:13 PM
nfnsquared's Avatar
Under $60 shipped on eBay. Don't think O'reilly can beat that.
Old Jan 6, 2010 | 08:13 PM
csmeance's Avatar
NGK's ONLY, the Denso's aren't as good as the NGK's.
Old Jan 6, 2010 | 08:49 PM
usually how much for each? checked on amazon it is like 20 for one?
Old Jan 6, 2010 | 10:41 PM
friesm2000's Avatar
B A N N E D
as said before NGK or Denso; end of story; but yeah NGK's are preferred
Old Jan 9, 2010 | 10:37 PM
changed the Bosch platinum ir fusion plug today feel smoother acceleration.
Old Jan 9, 2010 | 10:41 PM
friesm2000's Avatar
B A N N E D
such the wrong plug for our cars :shakehead
Old Jan 10, 2010 | 01:11 AM
gotkilled's Avatar
NBP is a pain...
here's the link to the 6 ngk iridium plugs btw. thanks nfnssquared. gonna grab a set. don't forget to combine w/ bing cashback
Old Jan 10, 2010 | 04:48 AM
01tl4tl's Avatar
get the bosch plugs out ASAP- they are the wrong plug and dont work very long before having issues
At least now you can still get a refund for them selling you those pieces of....
The car is labeled NGK or Denso, so why would you buy a german plug for a japanese car?
Old Jan 10, 2010 | 07:39 AM
ggesq's Avatar
why start a thread and then ignore everyone in it?
Old Jan 10, 2010 | 08:07 AM
nfnsquared's Avatar
x2. What the heck? If you keep that up, people are just going to ignore your request for advice. Why bother?
Old Jan 10, 2010 | 09:50 AM
TLDude876's Avatar
Chapter Leader (Houston)
Not a bad deal here on ebay. NGK Iridium FTW!!!
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Jan 24, 2010 | 11:22 AM
tg900's Avatar
3GTL/1GTSX
Hey where did you pull that cool table out of? I've been trying to find some how to's on routine maintenance,i.e. changing plugs, but i have no luck. I've only owned american cars, and this might be a bit more tricky. It's good to have a guide to go by.
Old Jan 24, 2010 | 11:27 AM
friesm2000's Avatar
B A N N E D
table is from the owner's manual :shakehead
Old Jan 24, 2010 | 12:41 PM
nfnsquared's Avatar
It's actually from the Service Manual, but the same info is also in the owner's manual.
Old Jan 24, 2010 | 05:58 PM
vovka2007's Avatar
I think the Bosch will work just fine. But no doubt NGKs will last a lot longer and are more reliable. My buddy put some bosch like yours in his civic he raced. About 2k later, the tips on bosch melted. No doubt NGKs are the way to go. Auto zone got em for 10 bucks a piece. Not bad considering they are 100k plugs.
Old Jan 24, 2010 | 06:18 PM
friesm2000's Avatar
B A N N E D
bosch=:thumbsdow
and as basically just said the tips go/wear real fast, which is't too good for producing a GOOD spark to ignite the air fuel mixture
so kinda pointless when you gotta replace them in 2k miles
Old Jan 26, 2010 | 11:37 AM
corduroy's Avatar
NGK Iridiums duh.
Old Jan 26, 2010 | 07:25 PM
I hate cars's Avatar
One thing you guys need to realize is the iridiums are only there so Acura can sell the car with the "105,000 mile" first tune up. They're great plugs but not necessary as so many people believe. I pulled the factory plugs around 40,000 and replaced them with platinums one heat range colder. Now that it's turned 85,000 miles I'll probably replace them with regular old traditional plugs. The reason is I change them every 40,000 miles so iridiums are a waste of money for me. It's cheaper to replace normal plugs every 40K and get a picture of what's going on inside of the combustion chamber than iridiums every 105,000 miles. It's also not fun pulling plugs that have been stuck in the head for over 100,000 miles.
If you plan on going another 100K, by all means use iridiums.
As for others wearing out super fast because they're not iridiums, I will promise you it's due to a defect in the plugs. If regular plugs work in my GN with 29psi boost and over 100hp per cylinder, they're not going to have a problem in the TL.
The only real problems are the "gimmick" plugs. Stay with a normal single electrode non-multiple spark spark plug and you're going to be fine as long as you follow the recommended change interval.
Old Jan 26, 2010 | 07:34 PM
friesm2000's Avatar
B A N N E D
and anti-sieze if you want to go 100,000+ miles, makes life much easier when the time does come to change them again
anyways stock replacements work good for me , but i will proably replace them again at another 90K (so 180K total on the car) though, geneally wasted by then anyways (if i don't replace them before then though with colder plugs, for the power adders)
some of it is lazyiness for doing them though, and so wanting them to last
also about the multiple electrodes, check out alot of stock toyota plugs, they come with twin electrodes from the factory, but they are also DENSO plugs at least, and not some gimmicky ones
Old Jan 27, 2010 | 10:36 PM
lwhitted's Avatar
NGK Iridium
Old Mar 13, 2010 | 11:05 AM
SHaFT7's Avatar
just did the ebay buy. $57.95 shipped for 6 NGK OEMs. can't beat that anywhere.
Old Mar 18, 2010 | 12:23 PM
RJNN TL's Avatar
What's so bad about Denso? Please explain to me why NGK Iridium's are so much "better".
I used the Denso Platinum TT's..
Old Mar 18, 2010 | 04:29 PM
killersrt's Avatar
Labor cost on replacing plugs sucks. Due to lack of time, and just being flat out too lazy, I had the dealership do my plugs. 1.5hrs of labor and $250 later (oil change included) and I'm on my fresh plugs. I think it was the first time they've been done in 66k miles.
Old Mar 18, 2010 | 07:59 PM
Etohprn247's Avatar
KoolKatz..
All good info thanks fellas!
Old Mar 18, 2010 | 11:13 PM
KyJellyTL's Avatar
what Spark Plug Wires do you guys use with NGK Laser Iridium Spark Plugs??? Stock OEM Spark Plug Wires?
Old Mar 19, 2010 | 06:55 AM
Inaccurate's Avatar
I H C,
I am interested . What was the brand and model? Maybe a part number
Old Mar 19, 2010 | 07:39 AM
Just buy a Honda's Avatar
3rd Gear
The OEM PLUG, If Acura had a better plug they would put it in from the facory. Maybe some of these people are smarter than engineers at Honda. I forgot that Honda is a public traded company with millions at there disposal for R&D. Just a thought!
Old Mar 19, 2010 | 08:26 AM
You're one of those...
Engineers have a set of goals. One is a super long change interval as a selling point of the car. Iridium meets this goal.
However, plain old copper meets any performance goal that iridium and platinum can meet. It just won't last as long.
As for the cooler plugs, the engineers obviously weren't on top of the pinging problem, now were they? And once again a hot plug will not foul out as easily as a cooler plug. The tradeoff is it's more detonation prone.
Inaccurate, I'll get that number for you when I get off of work. They've severely limited internet use due to a few bad seeds looking at things you would not expect them to look at at work. Amazing.....
On NGK's website it breaks down the part numbers. I believe higher is colder but I would have to double check. They do make a colder iridium now too.
Old Mar 23, 2010 | 09:35 AM
dgarcia520's Avatar
all good feedback guys, thanks! I'm going with NKG next month, right now i'm at 75,900mi, new owner as of Jan'10.
Old Mar 23, 2010 | 08:58 PM
illOpTiCs's Avatar
7th Gear
Thanks for the input guys. I was recently wondering this myself. NKG it is!
Old Mar 23, 2010 | 10:25 PM
akash4u's Avatar
NGK is what my Mechanic recommends.
rms2008's Avatar
Hi guys
I own 05 AT with 73K on it.. when do I need put a new spark plugs?
thnx in advance
Old Mar 23, 2010 | 10:27 PM
subinf's Avatar
One on the right for me
Ebay has great deals on the NGK plugs. Just put a new set in this weekend. I paid 56 dollars for them with shipping.
Old Mar 23, 2010 | 11:37 PM
Originally Posted by Inaccurate
I H C,
Sorry I took so long, I've been lagging with everything lately. The first thing to go from lack of sleep is my memory lol.
Here's a link to NGK's page. I thought you would like the idea of a cooler plug. The only disadvantage is cooler plugs can foul out easier. But you have to figure the TL runs a fairly hot plug to pull off 105,000 mile intervals. I've seen no ill effects from one heat range cooler in the TL. In the other car I run 3 steps colder with no fouling problems. No performance loss and there's the potential for performance gain if they reduce detonation tendencies. Here's the link:
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
Old Feb 20, 2012 | 01:24 PM
slrate67's Avatar
Well, against the advice of this board I just replaced the plugs in my 05 TL with Bosch Platinum IR Fusion (4501) plugs. Bought 6 off of amazon for $34.50 and am just about to mail in their $4 per plug rebate which means I will have got the plugs for $10.50.
Fitted then myself and must say the job went pretty well. I had to use a telescopic antenna with a magnet on the end to retrieve the plugs as my spark plug sockets rubber wasnt picking up the plugs.
Oh and the TL has 125k miles and I do about 2.5k miles a month. I hope the Bosch's will hold up as well as the original NGKs, we shall see.
Simon
