What does TSX need to beat TL?
the k24a2 in the tsx actually has a lot of potential. fully built and worked internals, it can make nearly 300whp. but at that point you'd have spent enough money to upgrade to a TL
2003 Accord Coupe V6
Intake, header, exhaust and flashpro should be enough to hang with a stock Auto TL if not slightly pull on one (IMO), as long as the TSX driver was decent. In reality most TL Autos are running 14.9-15.2 at sea level. The only spot the TSX would easily pull would be if the TL hit 4th gear. No one is really racing past 100mph anyway. If the TL had any mods though, the TSX would be in trouble at that point. Would like to see a good run though!!
The following 4 users liked this post by anx1300c:
Received 2,599 Likes
Monte TLS,MAX (07-13-2013)
All motor
A V-6. Lolz. No, in all seriousness though forget drags. You could do some motor work strip excess weight to make the scales tip in your favor. You should have bought a bigger motor for that. Use power to weight and weight distribution to your advantage. Twisty road through a canyon provided you're not up against a 6mt TL that can get aggressive around corners, you can use the TSX to your advantage. The car is lighter on its feet and can maintain a little more corner speed where as the TL tends to push a little harder. Beyond that the TL is freaking fast in a straight line.
I wouldn't call the TL "freaking fast" in an era where stock 13 second sport sedans and affordable 12 second pony cars set the bar. The 6MT was "pretty fast" for around five minutes back in late 2003, lol.
mlody
12-04-2019 02:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
