what do you use to put ATF in the filler hole?
im planning to do a tranny fluid change on my car. what methods or what do you use to refill the tranny fluid back in the dipstick hole? i cant seem to find a funnel with a tube small enough to fit in the dipstick hole
maybe he has a 04 TL with oil jet kit installed?
Takes time, but just put a hose on the end of the funnel, or as shown on TV last week, purchase an enema bag from the local pharmacy. It will have the plastic tube with a shutoff. Get the one with the squeeze type shutoff on the tube opposed to one with the shutoff on the tip. Remove the tip and you'll, or the car will be good to go.
I used a turkey baster. Stick it in the dipstick tube, pop off the rubber bulb then stick in a funnel. Pour slowly so it doesn't overwhelm the turkey baster tube
With the leftover fluid you can pour some of the tranny fluid over a turkey and it really makes a delicious crust (don't use synthetic)
Why make it so complicated by going thru the dipstick?? The filler bolt is easily accessible and requires just a long extension for your socket and a long funnel to pour into. Not sure why the dipstick method is ever used, to each his own i guess.
pistacio
09-26-2015 09:45 AM
