What do i do at 100k
im pretty sure at 105k you will ned to change your timing belt. you may need to change out your tranny fluid and poss yout spark plugs. But i know for sure the Timing belt
Off the top of my head: Plugs, timing belt, tensioner, water pump, inspect valve clearance(105K normal driving). Tensioner and water pump are recommended. Auto trans fluid at 60K, then every 30K. Coolant flush at 60K(I think)
It's going to cost you over $1000 to replace the timing belt and the other little stuff (spark plugs, fluid, etc..). I would budget for somewhere around $1200-1500. That shouldn't be to bad, assuming that your car is paid off at 90K miles.
The car should have another good 80-100K miles left in it after that as long as you keep up with the regular scheduled maintenance. Growing up, my parents have abou $240K miles on the venerable Acura Legend.
02tljj
10-12-2015 10:39 AM
