weird noise in reverse
Whenever the humidity is high or it has rained and my car has sat for about 2-3 hours, the first few feet in reverse produces a high pitched metallic rubbing noise. Put my foot on the brake and the noise stops. Put the car in drive and move forward, noise stops. This only happens in reverse and after the initial braking it goes away.
I think the pads on the RR caliper are absorbing moisture and dragging on the rotor. One stop seems to adjust the clearance.
Anyone else having this occur?
More likely the rain has just gotten between the pad and the rotor and is acting like a lubricant. Have you ever noticed how after you wash your car the brakes tend to squeal sometimes? After you have applied the brakes a couple of times it usually quits. I'm pretty sure it's the same deal.
ImayBparanoidButNoAndroid
I've never had this happen on my TL but when I first had my 01' A6 I had the same problem. I took it in to the dealer but they were unable to replicate the sound or find anything wrong. It eventually went away after a couple of months. No problems seemed to arise from this noise.
the rotors rust, they are just steel after all, and the brake pads scratch the light rust powder off. When you say after rain, and after washing it, it just verifies it. look at them after they sit, they turn nicely orange. nothing you can do about it, they are just steel.
This morning as I was backing out of the garage it made the metallic scraping noise again!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
