WDP stain
Old May 20, 2004 | 08:26 PM
junk_99_dl's Avatar
WDP stain
My WDP TL was taken on an extended trip. After getting back, I washed all the bugs off the front. There was a large purple bug splatter that will not come off. When I run my fingers over the area, it feels as smooth as can be but I can't wash the stain off.
Any suggestions?
Thanks!
Old May 20, 2004 | 08:42 PM
rets's Avatar
Moderator Alumnus
Are you saying they're stuck at your engine hood and the front bumper?
WDP seems so easy to have stain sometimes, but darker colors has swirl effect instead.
I hate those bugs, always wipe them out after driving at night on the coutryside roads though... this could make them easier to be cleaned...
Old May 20, 2004 | 08:49 PM
caball88's Avatar
have you tried using bug and tar remover. spray it on the area and let it sit for a couple of minutes. wash off thoroughly and then use clay bar on the area if it has not been completely removed. WD40 also works well but will strip the wax off the surface of the car. you should also wash thoroughly after y the stain has been removed. wd40 is not good for the finish of your car if it stays.
junk_99_dl's Avatar
A bug left a stain on the front bumper in the paint. I tried washing it off as soon as I got back but no luck.
Old May 20, 2004 | 08:59 PM
junk_99_dl's Avatar
I tried WD40, no luck. I don't have a claybar but I'm not sure that will help. The stain seems to have gotten into the paint since the area is smooth and doesn't feel like it is on the surface.
Old May 20, 2004 | 09:06 PM
rets's Avatar
Moderator Alumnus
How's about getting some shots for us? Ppl may be able to tell...
TLrascal
Aug 3, 2018 11:00 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Silvermoon_Knight
Oct 22, 2015 06:25 PM
IIDXholic
Oct 8, 2015 07:53 AM
Dunnik
Sep 15, 2015 11:52 PM
