VSA Noise.
2006 TL
VSA Noise.
I went to visit my cousin in Phil., PA. this weekend and on the way there I was hit with non-stop snow (but the car handled like a champion). When I approached my cousins house I was trying to go up his driveway (which is on an uphill grade) and the VSA turned on (b/c of wheel slip). Each time it turned on it made a noise. I'm pretty sure it's normal but what exactly is it doing that causes that noise?? I doubt highly it's from VSA braking the wheel.
.:KCCO:.
It's a horrible sound. kinda sounds like the engine griding itself to slow the car down. Does the VSA apply the brakes? I thought it was cutting the engine off, not totally off though, to decrease the torque so that it stops the wheels from spinning.
2006 TL
Yep... that's definately the grinding noise i was hearing then. At first I thought something was wrong but I turned VSA off and quickly noticed that the VSA was causing it. I know VSA cuts off engine power - not sure about the braking. I'm just assuming.
Doesn't the VSA apply braking pressure to individual wheels in order to keep the car on it's intended path though? I know my mom's Jag S-R brakes the wheels... and BOY DID I FEEL IT! (The Jag is very intrusive with it's DSC system, however The TLs VSA is much more subtle but maybe it's b/c they don't do the same thing??)
Jamus22
06-11-2023 10:08 AM
4drviper
09-23-2015 09:00 PM
