Visor and trunk light bulb
Old May 19, 2013 | 09:34 PM
johnlim84's Avatar
9th Gear
im sure someone out there already asked this question but here it goes again.
how on earth can you get the plastic cap off of the visor light and also the trunk as well??
thanks
Old May 19, 2013 | 11:19 PM
jasongobin's Avatar
i would like to know as well
Old May 19, 2013 | 11:41 PM
jkopuffs's Avatar
havent done visors yet but im pretty sure you just slip a flat head under neath and work it out... for trunk its the same thing...
Old May 20, 2013 | 12:51 AM
Will Y.'s Avatar
Registered but harmless
Originally Posted by johnlim84
...how on earth can you get the plastic cap off of the visor light and also the trunk as well??
There are photos in this thread: https://acurazine.com/forums/3g-tl-2004-2008-93/diy-interior-lights-revised-622590/.
The 3G Service Dept./Garage has a long thread on replacing all the bulbs with LEDs: https://acurazine.com/forums/3g-tl-2004-2008-93/definitive-led-thread-all-youll-ever-need-know-about-leds-3g-garage-g-076-a-633045/.
Welcome to AZ.
Old May 20, 2013 | 01:20 AM
MEKO's Avatar
Make sure you do not rip off that metal frame for the visors
Old May 20, 2013 | 01:42 AM
spicynoodle116's Avatar
Newb
I remember its a lot easier to replace the bulb for the license plate by removing the trunk inner cover than to pry out the plastic caps from the outside. I broke one of the tabs while doing mine years ago when attempting to pry out the plastic caps.
Old May 20, 2013 | 09:40 AM
johnlim84's Avatar
9th Gear
Thanks guys much help ^^
Old May 20, 2013 | 09:11 PM
johnlim84's Avatar
9th Gear
Alright I suck at this.
The dang plastic cap would not come the f*** out.
On visor and trunk. I can get my screw driving in between them but can't get it out.
One more thing on the fog light I got the cover off but how on earth do u unplug the plug?
Hahaha I'm sure you guys understand my frustration hahaha
This sucks right now hahaha
Old May 20, 2013 | 09:41 PM
Newb
Remove the trunk inner cover and release the plastic cover by pressing the 2 tabs together~
https://acurazine.com/forums/3g-tl-2004-2008-93/e-035-diy-how-remove-trunk-liner-pics-763693/
MEKO's Avatar
For fogs, there is a clip on the plug. Click it and pull the bulb out
Rest? Give me a second
Edit: Hold on, license plate OR trunk light???????????
If you trying to remove the trunk light....
Insert the screwdrive from the passenger (right side) and push it to the left
It will pop out
That plug is on the left side, so can't take it out from the left
Took me a second to remove it
Old May 23, 2013 | 03:05 AM
johnlim84's Avatar
9th Gear
Thanks for the info I will try it this weekend ^^
mada51589
Jan 9, 2025 04:40 PM
PortlandRL
Sep 14, 2015 12:01 PM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
Mcj270
Aug 31, 2015 04:45 PM
