VIN number
Old May 17, 2004 | 08:55 AM
rescueswimmer's Avatar
VIN number
Just trying to find out what digits on the VIN let me know the build time. Thanks
Old May 17, 2004 | 08:59 AM
OmegaTL's Avatar
You can't decipher the build time directly from the VIN. There is a stamp on the driver's side door frame that tells the build date.
Here is really good link:
http://www.acura-tl.com/forums/showt...threadid=67654
Here is a quote from that link so that you don't have to click the link:
Originally Posted by Hybrid
How to decode:
Example VIN: 19U UA6 5 5 * 4 A 000001
In order of grouping above (note added spaces):
19U Honda of America Mfg., Inc. USA, Acura Passenger Vehicle
UA6 Acura TL/J32A3 (model code)
5 for 6 speed, 6 for 5 spd. Automatic (kind of backwards)
2 for A/T, 5 for 6 spd. M/T, 6 for 6 spd. M/T with hi-per tire option
Check digit - there's a formula for this that can be found with a web search. Basically, it's a letter or number calculated based on other VIN letters/numbers. If it's "wrong", it means the VIN is wrong.
Model Year (4 is 2004)
Factory Code (A is Marysville, Ohio)
Serial number (starts with 000001 for USA model, starts with 800001 for Canadian model)
The example code above would be a 6 speed manual without the summer tire option. Check digit wouldn't normally be a *.
Old May 17, 2004 | 09:51 AM
Ok now that I have that figured out anybody know what are the later build numbers that have most of the first year bugs worked out thanks again
Old May 17, 2004 | 09:52 AM
Tripp11's Avatar
Newbie for Life
Mine's 28,XXX and I don't have a single problem worth mentioning.
Old May 17, 2004 | 01:20 PM
rets's Avatar
Moderator Alumnus
Don't know. Later built 04TLs should be having less issues.
Old May 17, 2004 | 07:41 PM
OmegaTL's Avatar
I am not sure, but Acura is up to VINs around 48,XXX. I thought that might be of interest.
Old May 17, 2004 | 08:15 PM
Goldglv's Avatar
Omega, you're right, I just got my VIN today and it's 48,XXX
08KBP_VA
Oct 22, 2019 01:55 PM
emailnatec
29
Sep 28, 2018 04:27 PM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
thegipper
Sep 28, 2015 01:01 PM
eastcoastguy
Sep 23, 2015 06:29 AM
