Vibration at 1500-2000 rpm
Old Sep 4, 2004 | 06:55 PM
MNP's Avatar
MNP
I just took a 1200 mile trip in my new AT TL (1800 miles total). I love this car.. but: I seems that at about 1500-2000 rpm there is a little vibration or roughness... it goes away completely at 2200 rpm and up. This is not tire vibration (I have Michelin Pilot Sport A/Ss) since it happens at different speeds at that rpm. It is not serious, but the car is noticeably smoother at the higher rpms. I would describe it as a little vibration that comes up through the gas pedal. Does this sound familiar to anyone?
Old Sep 4, 2004 | 07:02 PM
I get a feeling that seems like an acoustical harmonic hum when I'm at about 60-65mph @ 2-2.5rpm. It seems to me like an exhaust hum/vibration and not tires or tranny. I presume its normal but not sure, I don't believe the stuff the dealer tells me. I have a 6MT. It doesn't bother me much. The thing that bothered me the most was the EL42's which I replaced with Michelin Pilot Sports A/S. Everything else is okay and I love the car.
Old Sep 4, 2004 | 07:53 PM
rets's Avatar
Moderator Alumnus
5th gear/1500 RPM/50-55 MPH... at my 5AT...
MNP,
IMO, you're probably the few 5AT 04TLers having Michelin Pilot Sport A/S still sensing and complaining this vibration, "resonance of exhaust". Acura calls it as characteristic.
In my case, 5AT, I have been experiencing this since Day 1, but I got "less" vibration at this particular speed/gear/RPM after replacing my EL42s. Remember, some 5ATs do have this issue, others don't.
We started to talk this issue since Oct., and discussed all the possible factors among Engine, Tranny, Engine Mount, Dampers, ECU shifting map/program, torque converter, exhaust, etc. Ok, since Acura MDX release the TSB to help fix the similar issue (2k RPM). This problem is probably caused by "resonance of exhaust". Acura then agrees this is characteristic, and they have no solution for it YET.
I used to downshift to 4th gear and lift RPM higher to get rid of this uncomfortable zone.
Old Sep 4, 2004 | 09:37 PM
need4spd's Avatar
an Acura has-been
MNP, Sorry to hear you are having this problem with your TL with a current build. Acura knew of this issue late last year like Rets indicated, and they were not sure when they would have a fix.
It is an exhaust resonance issue by thier admitance, and could not fix it. It happened to me at 1500rpms and more noticable at 30 - 35mph and 50-60mph (also at lower speeds) when maintaining speed and moderate to lite acceleration. This caused both a vibration in the car and a droning noise, with more vibration in the 50 to 60 mph range.
Good luck with this issue.
Old Sep 4, 2004 | 10:32 PM
MNP's Avatar
MNP
Yes..that's sounds like the problem I'm having. Mine is a recent build 62xxx. How do we know that Acura is aware of this...is there a bulletin or something? Are they working on a fix? Will my dealer pretend that there's nothing wrong?
Old Sep 4, 2004 | 10:56 PM
need4spd's Avatar
an Acura has-been
Acura knows, there is nothing in writing though. They knew in late 2003 of the issue, and it seems no fix to date, Acura was not sure when a fix would be available as of last Spring, and it looks like they still have not worked it out.
Old Sep 5, 2004 | 03:12 AM
rets's Avatar
Moderator Alumnus
http://www.acura-tl.com/forums/showthread.php?t=91133
http://www.acura-tl.com/forums/showthread.php?t=88174
http://www.acura-tl.com/forums/showthread.php?t=90614
Old Sep 5, 2004 | 04:40 AM
need4spd's Avatar
an Acura has-been
Thanks Rets, good info!
Old Sep 5, 2004 | 08:33 AM
MNP's Avatar
MNP
Thanks for all the info... clearly, my problem is the "exhaust resonance" or whatever you want to call it..and nothing to do with tires. Although the problem is not major, it is absurd that I've just pluncked down over 30 grand and have this problem.
Can someone please give me a name and address for the head of customer service or the appropriate dept of Honda/Acura. I work for a major news organization, and I think it's time for an inquiry on letterhead. Thanks for all your help.
Old Sep 5, 2004 | 05:52 PM
rvmeush's Avatar
I think some exposure of this problem in a major press outlet would go a long way toward helping to get this resolved. MNP, please see what you can do.
Old Sep 5, 2004 | 08:18 PM
GTFISH's Avatar
ACS doesn't care, in my experience. Basically said I would have to live with it unless they found a cure to the vibration. They were the least bit sympathetic nor accomodating. Fortunately my dealerships service manager is understanding and willing to do what he can. I am meeting with my district service rep shortly and will report back the findings.
Old Sep 5, 2004 | 10:37 PM
glennson's Avatar
Glernson
This is a great message board. I already benefitted by learning how to hook up my radar detector. (I digress) I just picked up my new TL 2 weeks ago, I also feel what I thought was an upshift vibration at about 1800 rpm's. I will continue to monitor your progress with the issue.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
