V3 Triton Switchbacks
So this might have been gone through already, I've done a quick search but results came to 0.
I know this system is basically a plug and play, but i really dont want to take the headlights out.
Would some one happen to know how exactly to install these? which spacers to use? and how far in to turn the bulb in?
https://acurazine.com/forums/showthr...874983&page=12
https://acurazine.com/forums/showthr...=878471&page=3
Both threads will give info and that is where I found out what size gasket to use. I adjusted the lens to match the length of the OEM bulb. You just go in through the fender area s very simple and accessible. The tritons are awesome and worth the cost IMO. The gen1 version had issues but gen2 seems to be working great.
If you have any more questions just ask in the 12 page thread above, a lot of people in there will respond quicker than your new thread. You can also PM me if you want
Oh yea as a heads up, you get better search results on google typing "acurazine tl" and then whatever subject you're looking for. The threads above popped up that way also
Jriddle8 (12-26-2013)
Typing "site:tl.acurazine.com" into Google before or after your search query will yield results only from this forum. Very similar to the method I quoted, but it will filter out anything not from this website.
No headlight/ taillight removal necessary. You use the same method you would to change the standard bulb.
To make things easier though I recommend jacking the front up a bit and pulling back the front portions of the wheel well liners for easy access. This is a very easy thing to do though. Just a couple pushpins and it pulls right back.
rodneyc77
3G TL Photograph Gallery
225
06-05-2015 09:50 PM
