V-LED New DRL Harness
#81
The pictures were taken with my Droid. But I'll take better pics with my DSLR.
#82
i got my kit installed yesterday. looks awesome. the only thing i didn't like was they didn't send instructions.
they obviously made instructions based on the pics that were posted in this thread. i think they should have sent them with the kit.
otherwise, it looks great.
#84
So if I would like to change out the fog lights as well to match the DRL with the high power harness kit, should I get the relay wiring kit for the 9006 bulb? Does anyone know or have anyone tried it out?
#86
Help!! I just installed the harness today, and my DRL warning light comes on everytime. I followed the instructions for connecting resistor harness to the original factory connector, then connecting the resistor harness output to the relay harness, then the led bulbs go onto the relay harness. But I have a DRL warning... What am I doing wrong? Also, do you guys know if I can put a regular bulb in for the LED, maybe that will make the light go away but still have the full power?
#87
Have you guys had any issues with the LEDs turning on and off intermittently? I installed mine on Sunday, so yesterday was really the 1st day that I drove around with them. I can really only tell if they are on by looking at the reflection in the car in front of me. It was hot as hell here in Chicago yesterday and my guess is that they are turning off when one of the components gets too warm….any thoughts? They work fine in the morning when it’s still cool outside, but during my drive home they would turn off at some points during my drive. If it is a heat thing….what component is the most temp sensitive? BTW...both of them were turning off at the same time which leads me to believe that it's the relay getting too warm? If so, where did everyone else instally their relay? I mounted mine with 3M tape to the side of the battery enclosure to prevent drilling any holes.
Otherwise they look great!
#89
I'm really looking forward to getting this on my TL-S. I got the perfect excuse since it's at the shop getting the whole front end replaced. BTW I think I've seen your car around WhteTLS because I live in the same area.
#90
oh really? Where in Falls Church you live? What color is ur TL-S?
#92
oh nice.. Yea I live at Skyline Plaza, but I'm moving to Alexandria next week into Cameron Station Area.
We should definitely have a mini car meet after your car is out of the shop. Hit me up when your car is out.
#93
I was looking for a car meet in the area. We should definitely do one in the NoVA area. I got three weeks before she's on the road again
#99
#101
#102
I am installing the kit right now and I got a drl warning light and according to vleds site it says their harness should have a yellow wire but it doesn't and my aren't bright like Whitetls's are.
#104
What a joke, they just won't stop increasing the price now huh? Up to $104.99 + shipping now for a product that probably costs a fraction of that to make...
http://www.v-leds.com/Exterior-LED/D...87941-2-1.html
#105
WOW these things look fantastic but $104.99 is steep! I mean I love the fact that they actually look perfect as DRL's almost like xenon matched lights but I'm not sure I can fork out $104.99 for some DRL's. They are nice though. Are they going to have any kinda group buy deal or something?? Do those coupons still work? (the 15% one that's on the forum?)
#106
#110
ok, so my LED DRL kit came yesterday. tried installing it today, but ran into a few problems.
- instructions show yellow wire to black wire connection. my kit didn't come with a yellow wire. basically put the kit together so that all the connectors locked properly.
- drl's would not turn on. no error code in the dash either.
- i unplugged the harness and went back to the original set-up w/ the normal bulbs.
- drl's still would not turn on. no error code in the dash.
- now i'm confused.
any ideas/suggestions? thanks!
- now i'm confused.
#111
- now i'm confused.
- now i'm confused.
Whitetls's kit is from ebay not vleds. I would pm him to see if he can post up his hook up or at least help you out.
#112
ok, so i played around with the harness some more last night, and i got some very interesting results:
- first, i had no lights & no error codes.
- swapped the resistor cables. no lights, but got an error code.
- swapped the resistor connector polarities. no lights, but got error code.
- took off the harness. plugged the LED bulbs straight into the DRL connector... success!?!?
so i basically used the LED bulbs w/o the resistors or power harness. they light up, and there is no error light! i'm not sure if they're running at 100%, but they're bright enough for me. go figure. anyways, i'll call v-leds to see if i can return the harness.
on a separate note. today, i got a warning telling me to tighten my gas cap. i checked it, and it was on securely. you don't think it could be related to the lights do you? should be a separate issue.
#113
That is weird. I just started to get that warning as well like 2 weeks ago. But I had the LED Harness on for over 2 months now. So I don't know..
#115
i called V-Leds. they're sending me new harness because mine has some issues. so far, great customer service.
#116
#117
#118
Ok so here's the scoop....
The harness that we have with the red wire that's says it's yellow is correct. This is a new harness they made so they changed the wire. The issue everyone is having is that the clip is reversed first off and I mean the clip with the single black wire and the single red wire. If you guys have noticed as per the instructions you wouldn't be able to clip the harness to the oem plug and thats because of that issue. Next up is the drl code issue which is being caused by the harness pins pushing back out when you plug everything in. So take the pinned wire out from the harness plug of their kit and just slip it into the correct slot to test everything out to confirm this. When you see that you don't have a drl code then you should be good to put it back to normal but make sure the pins don't push out as you are plugging in the harnesses.
I got this info from v-leds tech support direct just awhile ago I haven't tried this yet myself but he did acknowledge the issue we are having and has dealt with a few people here already. i told him i would get back to him tomorrow to let him know if I had success with it or not.
As it is right now I do have the bulbs in without their harness in and I'm not throwing a code and one bulb is somewhat brighter then the other but not by much. But I don't really feel comfortable with it this way without the harness in so I will take a swing at it tomorrow.
#119
thanks for the info cubanlynx84. i'm in the same boat as you. that was the same info i got from tech support. just waiting for a replacement harness to come from v-leds. a few of the crimpers on mine came off.
btw... did you have to mount the black box on the harness to a grounded source? does that make a difference?
#120
