Upgrading Center Channel on TL
Old Feb 27, 2004 | 12:08 AM
bkeepper's Avatar
Greetings,
I am planning on upgrading my stereo in my 04 TL w/ Navi.
Two different installers have told me that I would have to keep the Factory Amp in order to retain 5.1.
Basically they are saying run the head unit to the factory amp, and then run from the factory amp to my aftermarket amps running the upgraded speakers.
Does that sound right?
Also, I would like to run a 5-channel amp, running the center channel speaker, the front components, and the rear components. Then a two-channel running the subs.
Will this config work, and can I remove the factory amp from the equation and still have surround sound (I am keeping the factory deck)?
You advice is appreciated.
Thanks,
Ben
Old Feb 27, 2004 | 07:16 AM
Z Factor's Avatar
Hello, and welcome to the forum.
I would suggest that you call Acura Corp. and get a definitive answer from them as to what components must remain. I have an older 300ZX, and want ed to swap a few things out back in the day. Installers told me several conflicting things, so I called Nissan, spoke with a knowledgeable technician, and got the right info.
Good luck
Old Feb 27, 2004 | 07:22 AM
harddrivin1le's Avatar
Re: Upgrading Center Channel on TL
Originally posted by bkeepper
Greetings,
Thanks,
Ben
I suggest that you retain the stock set-up.
The money would be far better spent on s decent set of shock aborbers once someone offers them.
Old Feb 27, 2004 | 07:32 AM
vtechbrain's Avatar
Re: Re: Upgrading Center Channel on TL
The money would be far better spent on s decent set of shoch aborbers once someone offers them.
IBID!
mlody
Dec 4, 2019 02:11 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
