Unpainted Brake calipers.
Hi,
I thgoht all of the models have "ACURA" on the brake calipers. I have a 5AT/Non navi but they r not painted. Y is this? Any way to paint them?
G2 Paint
http://leatherz.com/Merchant2/mercha...gory_Code=Mini
Dips
Check out this site or do a search for G2 Paint system. I have used it on an S2000 and also painted the calipers on an acure TL and they came out great! They resist the high temps and the paint is exetremely durable.
Dips
BOOK EM
I`ve got the 6MT and painted the rears with VHT brake and caliper paint. Just clean the calipers with a little Fantastic or similar, and just spray on the paint. No step by step hassles with other brands.
Originally posted by dips009
Thanx for the info.....any idea on how I can have ACURA written on it? Stickers etcccc.
so this has been done before??? somone has fitted the brembos on an auto???? i thought there was a fitment issue and that was why acura decided to include the brakes in the auto.
If you go to www.decalgirl.com they will make any kind of decal for you calipers. They use high temp. stuff so it won't melt under the extreme tempatures.
site gen... :lol1: i think i'm going to paint my calipes black and then get some white decals made to match my car....
Andrenaline Junkie
Re: Unpainted Brake calipers.
Hi,
Hi,
I let them dry for 24 hours and then drove. I think the heat from the brakes cured this paint really well because it is very hard and does not scratch easilly. I have sprayed it with a high pressure sprayer numerous times now and it doesn't affect it. It looks as good as any powder coat I've seen. All the brush marks leveled out and are non-existent.
Since I don't have digital camera, I am waiting for the good old fashion Kodaks to come back and I will scan and post them.
Team SSM
I did the same and I'm very happy with the outcome.. I did it all for about $10. Good luck
Originally posted by Skeedatl
I'm not sure at all. I just saw the auction listed. I would guess for production sake that the wheels are all the same, but the proportioning valve, ABS settings and stuff may be setup different. Hopefully someone with more experience that knows will read the thread. If they weren't much more than $1K I would consider putting Brembos on, but I don't think they're clear my wheels is they stick out much farther than the regular ones. I can barely get my finger between my new wheels any my stock calipers as it is.
Team Nghthwk Whipping Boy
Originally posted by copter
Ditto!
Ditto!
So I take it, its just a simple tape-off job to get down to the exposed areas you want to paint?
Wicked.
Team SSM
Wicked.
Wicked.
When all else fails; the search function
08_UA7_Gr33k
02-11-2016 02:17 PM
GWEEDOspeedo
01-15-2016 10:39 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
