Type S Power steering pump worth it ?
Old Mar 17, 2014 | 08:52 PM
mattymattB's Avatar
From Around The Way
My rack and pinion is shot and my power steering pump is leaking through the body pretty nicely.
I found this place through google that sells remanufactured steering racks OEM for $115 with a lifetime warranty after you send back your old one.
http://www.steeringrackandpinion.com...ck-and-pinion/
My steering is sloppy as hell and it darts all over the place unless i hold the steering wheel with 2 hands and this is after getting a wheel alignment even.
I've changed everything on the front end so im hoping this new steering rack is it. I have 153,000 miles and im the 2nd owner so i can only assume its the original.
I've learned through searching the forum that there is no difference between type s steering rack and the regular so im not concerned with how firm that will be.
My question....
Im wondering if it's reallly that noticeable the increased firmness from the type s power steering pump. Or should i just replace the o-rings and seals on the base power steering pump I have now that's leaking ?
Old Mar 17, 2014 | 10:15 PM
Chad05TL's Avatar
These TL's are bad about darting all over the place even if you have a good alignment. It takes a very specific detailed alignment in order to get rid of that darting nature but there was also a service bulletin for this issue too. (not a recall).
If you replace the rack, I would get the type-S rack because the numbers of turns from lock to lock is fewer.
If my steering pump was leaking with that many miles, I would buy a new one. But if you go to this website, it shows the typeS pump to be the same as the base TL. http://www.acurapartswarehouse.com/
The difference is in the "gear box" which is the "rack & pinion".
lastly, $115 with free shipping both ways sounds really cheap. And for a lifetime warranty, those are only as good as the company stays in business and I would wonder what they are doing to the reman'd rack.. It doesn't sound like much. So I am skeptical. But hey if you try it, let us know how it goes! haha We need pioneers!
Old Mar 17, 2014 | 11:38 PM
DrTynanol's Avatar
check outer-tie rods, they tend to make the steering wheel sloppy when there damaged
edit: nvm, u replaced everything on the front end
Old Mar 18, 2014 | 01:26 AM
paperboy42190's Avatar
Incorrect. Type S power steering pumps have a different part number than base TL's.
Old Mar 18, 2014 | 07:25 AM
AdAstra's Avatar
Mechanical Engineer
I can't comment on the difference between the PS pumps (if any), but I would spend the $8.50 on the O-Rings and do the overhaul. Assuming its just the seals and not the pump itself. Rockstar143 has an excellent DIY below with part numbers and everything. I did mine about 3 months ago; haven't had problems since. Might be worth a try before buying a new pump. Good luck OP!
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-pump-overhaul-pics-sm-scans-841134/
TL-Rocket
Apr 29, 2023 02:33 AM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
asahrts
Sep 4, 2015 05:55 PM
