Tuning
Old Dec 29, 2024 | 06:45 AM
E39's Avatar
E39
Tuning
I have a type s auto. Mods are cai, 3.7 tb/im HFPC, ported runners, atlp j pipe. Would the car benefit from something like a k tuner to any significant degree. Or is stock ecu good enough.
Old Dec 29, 2024 | 11:39 AM
marklittlefield4's Avatar
Stock ECU is good enough, however the big difference with a tune is drivability. I have a similar mods list, and after my own research, I decided to pick up a hondata for my 08 base AT. Planning to use E Tunez to get everything dialed in for me.
Can I ask - did you have any trouble with the J37 throttle body? I've been having a hell of a time trying to get mine to work. At this point, I'm considering getting a p2r adapter and just running my stock TB with the J37 intake manifold. Thoughts?
Old Dec 29, 2024 | 02:10 PM
Actually, I was mistaken. P2R does not make an adapter for a j32a3 tb on a j37 im, only a j32a2 tb. So, I guess I can either run my stock tb/im setup or troubleshoot the j37 tb/im. I'd rather get the bigger tb/im working, of course. Did you run into any CELs or anything with yours?
Old Dec 29, 2024 | 02:20 PM
E39's Avatar
E39
No cels. It should work fine. My mechanic did a throttle relearn though with his fancy scanner maybe that’s what you need to do. Also I had the p2r spacer for the j37 throttle body and felt I lost throttle response and ended up taking it off.
amk6453
Apr 8, 2011 07:59 PM
drogersbruh
Mar 1, 2010 06:49 PM
bballislife010
Jun 25, 2009 05:45 PM
604NIGHTHAWK
15
Apr 1, 2009 11:18 AM
jags2487
25
Feb 27, 2008 08:16 PM
