TSBs for '04 TL
TSBs for '04 TL
Don't know if this was posted yet but it looks like the TSBs are finally starting to show up. I guess that Acura finally released them.
Bulletins for 2004 Acura 3.2TL V6-3210cc 3.2L SOHC
Service Bulletins
TSB Number Issue Date TSB Title
04-015 MAY 04 ABS - Lamp ON/Possible DTC's 15, 16, 17, 18, 43, 44 Set
04-006 MAR 04 Audio System - Service Diagnostics
04-005 MAR 04 Interior - Drivers's Seat Memory Function Inoperative
04-004 FEB 04 Computers/Controls - HIM Module Updating
01-026 JAN 04 Engine Controls - ECM/PCM Reprogramming
03-033 DEC 03 Engine Controls - MIL ON/Misfire DTC's Set
00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
03-013 SEP 03 Navigation System - Operation/Initialization
Service Bulletins
Has anyone ever tried to request research from this site? http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
Moderator Alumnus
Looks pretty accurate.
You may need to add a few more.
04-020 July 09, 04 - Safety recall: CL and TL Automatic Transmission Second Gear Inspection
04-016 July 23, 04 - MIL COmes On With DTC P2195 or P2197 (Supersedes 04-016, May 21, 04)
http://www.acura-tl.com/forums/showthread.php?t=75525
Moderator Alumnus
This one couldn't provide the detailed Acura-like TSB info.
Team Anthracite Member
Hi,
I'm kinda of dumb about automotive technical stuff, but are TSBs all the problems that they've had to fix, compiled into a list, and given out to all dealers?
In other words, are those the only problems I MIGHT run into if I get a TL? Or are there more?
thanks a lotto,
carcar
thanks a lotto,
carcar
Moderator Alumnus
Each TSB will specificly apply for
It doesn't mean you car need to have all TSBs update, however, your dealer at least should run VIN check into their computer system and make sure those #1 category TSBs has been fully applied into your cars.
For example, any 04TL before VIN 18476 should have TSB 04-005 (Driving Position Memory Module) done. Any 04TL before VIN 14224 should have TSB 04-020 (Auto tranny 2nd gear inspection recall) done. All this category TSBs should be done automatically by your service dealership without any 2nd thoughts or hesitation.
As for TSB 04-016 (MIL comes on with DTC P2195 or P2197), without having those error codes inside your ECU, you have no need to get that TSB update.
IMO, most of new cars should be trouble-free with those old TSBs.
- the certain VINs (group recall, update, or replacement)
- error codes (MIL, or misfire)
- whoever meets that standard and criteria. (Navi failure, brake, Audio, or ABS)
"Would these problems be found in any 05?"
Yes, I've had my '05 TL for one week and the memory seat buttons have never worked -- I mean they are completely dead. I took it to the dealer yesterday. They indicated that the '05 memory system is different than '04 Tls and that TSB 04-005 (Driving Position Memory Module Replacement) does not apply.
some TSB's are just for informational purposes only. some provide technicians with tips on how to do repair. the owners will get "recall" notice if something needs fixing (like the 5AT gear issue).
if you spot a TSB and it applies to you, you can have that TSB performed, otherwise the dealers are not calling you to notify you about any TSB.
Originally Posted by terse
would these problems be found in any 05?
If your car was built after a TSB came out, the TSB wouldn't affect your vehicle. It is MUCH cheaper to fix the assembly process than to reimburse service departments for warranty work.
TSB's in Canada are different for some insane reason. Is there a memory seat TSB for Canada yet?
I went to the dealer with the issue once, they tried it out and it worked and there was no TSB so they didn't do anything. If there is one now I can tell them to look it up and fix the facker.
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
02-26-2016 03:44 PM
