Trimmed door locks?
Old Oct 23, 2008 | 10:29 AM
jmkiang's Avatar
zaino'd
Trimmed door locks?
I think MichaelBenz has this done but I can't find the pictures.
Basically, when the car is locked, the door lock rods retract all the way into the hole.
How is this done?
Old Oct 23, 2008 | 11:10 AM
rockyfeller's Avatar
King of NYC
https://acurazine.com/forums/3g-tl-2004-2008-93/alarm-blue-led-mod-short-door-lock-pin-mod-603260/
There you go man, this is my thread. There is another descriptive thread out there somewhere too.
Old Oct 23, 2008 | 11:32 AM
jmkiang's Avatar
zaino'd
^ Sweet man exactly what I want to do. I know you just sawed part of it off but how does it reconnect to the car? I guess I will know once I remove my door panel... but I thought I'd ask anyway.
When installed my moleskins, I tried to remove the door panel (I know, not necessary) and I couldn't get the back screw (in the rubber bump stop) out. It just kept spinning! I will be installing my KP module soon and need the panel off. Has this happened to anyone here?
Old Oct 23, 2008 | 02:04 PM
LoveMyTL-S's Avatar
That screw must come out very slowly or you will strip it. Take a screw driver (flat head) or needle noise plyers and run it behind the rubber gromet and hold it against the metal. Then try to unscrew it. It should unscrew then.
Old Oct 23, 2008 | 03:50 PM
King of NYC
That's right, it is a stupid design. Many including me have a problem with that screw too. The plastic screw holder easily gets stripped against the sharpness of the sheet metal.
When you saw the lock pin the thread will still be able to catch so there is no problem with having it thread back onto the car. What you essentially are doing is cutting a little length and thread off the pin that's all. It is wise to cut conservatively and a little at a time. Better than going too short. You can test fit it quickly to see if you have the appropriate height you need and repeat if necessary.
Old Oct 23, 2008 | 03:59 PM
jmkiang's Avatar
zaino'd
Old Oct 23, 2008 | 06:05 PM
dmarcus48's Avatar
BTW it is SO nice not to have those locks sticking in you arm!
Dave
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
BIGxRED
Oct 19, 2015 10:47 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
