Transmission rebuilt question on '04 TL 5at
well i recently started to get the blinking light next to the d and i been searching in the forums which say to do the pressure switch and 3x3 atf change i havent had any problems driving drives smooth and gears goes in fine ima be taking it to the dealer tomorrow to get it check out but if worst comes to worst i will have to rebuilt....i went to check at a transmission place and they told me theyll charge me 1500 with 1 year warranty is this a good deal or good to be truth? what shoould i look into if i do end up gettin it rebuilt any parts i should buy on my own like sensors???
anyone??
anyone??
sound like a legit shop, but make sure you get that 1 year warranty.
yes i will be gettin a paper signed stating wat i got done and replaced and wat exactly the warranty covers im very uptight with that as a had had problems before with warranty anyone know an estimate the dealer would charge to do that?
I recently had to rebuild my 2000 F150 4x4 transmission and everyone i spoke with had a 1yr 12k miles warranty and the cost was $1200 +/- 300 dollars. i finally found a guy that done it for 1000.00. that included all the parts and labor. i know a ford is not an acura but it seems an auto tranny rebuild is normally around 1500+/-. I would recommend getting the warranty in writing.
ep3kid914 (02-22-2012)
Dogmatic Dinosaur
Do a 1x3 with a quality fluid every time that you change your oil and see how much longer you can go. You might be surprised how long it will last.
thansk guys jsut came from the dealer the light was due to 3rd pressure switch i just replaced that along with the 4th and doing a oil trans change tomorrow will the light continue to blink even though i replaced it on its own or i have to erased it with the comp
marcelft
07-10-2018 06:17 PM
Mike Bertram
09-10-2015 09:27 AM
asahrts
09-04-2015 05:55 PM
