Transmission Problems After Pressure Switch Replacement?
I'm looking at buying a 2004 or 2005 TL but I have a few questions:
1) After changing the pressure switches do people still have problems?
2) Is there a point where even changing the switches won't help? If I were to get one it would probably have 80-90k miles.
3) Is there a percentage like "20% of '04 TL owners experience transmission problems"?
4) Do they like to be driven hard?
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
1. I did the pressure switches but I wasn't having tranny problems to begin with. (05 TL)
2. Yes.
3. Dont know. You do have a higher probability of having tranny issues with the 04 and early 05 TL's.
4. I don't drive my car hard but that doesn't mean others don't.
2. Yes.
^ not a good plan.
Right. You said you weren't going to change them at all. It is a good preventative maintenance item. If the tranny is bad then it may not matter. I would still do them no matter. However, if it is operating normal then it's a good idea to do them.
TLX-S
I bought my '04 TL with 44k on it and now I'm at 80k. Shortly after I got the car, I swapped out the switches as a precaution and I have no issues. I also changed the ATF to Redline Racing around 60k, then changed is a mix of Redline Racing and D4 around 70k.
I also made sure the '04 I got didn't fall under one of earlier '04 models that had more issues. There's TSB out there that specifies the VINs affected.
mada51589
05-03-2022 08:54 PM
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
