Transmission mounts. OEM?
Old May 11, 2023 | 10:42 AM
robster80's Avatar
Need to replace motor and trans mounts. From what all im reading about the motor mounts it looks like its best to stick with oem. I hate vibration. Im guess stick with oem on transmission as well? Or is there a solid non oem brand for both motor and trans? Ive got a LOT of maintenance to do on this thing (07 type s , 250k miles) but if i can save a bit of cash id certainly like to. If go OEM on trans mounts does anyone have the part numbers so far ive found 50879-sep-a01
Old May 11, 2023 | 11:39 AM
bitterbuffalo's Avatar
There is a lower trans mount too. the 07-08 mount is difficult if not impossible to get out without dropping the subframe. 50850-STX-A03
Old May 12, 2023 | 02:25 AM
mariusz439's Avatar
I replaced all mounts without dropping subframe - just used the jack for lifting little bit the engine and trans.
Old May 12, 2023 | 08:50 AM
robster80's Avatar
do u know the part # of the other trans mount?
Old May 12, 2023 | 09:03 AM
There are only 2 trans mounts, the one you posted, the upper. the one i posted is the lower.
Sparky16
Aug 5, 2024 02:48 PM
Vadies
May 12, 2019 02:14 AM
SuperGreg
Jul 10, 2018 04:47 PM
prinster21
Aug 1, 2017 09:05 AM
ABP_04TL
Jan 3, 2012 08:23 AM
