Transmission Fluid Change Soon
Is anyone using Mobil 1 synthetic? I know there has been a lot of discussion here as which one to use but Mobil 1 seems like a good all around fluid don't you think? How many quarts does the TL hold?
BANNED
check out the 3G garage. all your answers are found there. also check your owners manual.
https://acurazine.com/forums/showthread.php?t=84831
your topic has been discussed numerous times.
I have 70K on my TL and not sure if the Tranny fluid has been changed. What is the recommended interval under normal driving conditions? Is it 100K and is Mobil 1 synthetic ok to use. I see where ATF-Z1 is recommended but is Mobil 1 compatible?
BANNED
acura says every 60k change your atf. but it is always a good idea to get the Z1 fluid out of there asap. most go with redline atf, read this thread.
https://acurazine.com/forums/showthr...7#post12805707
Dogmatic Dinosaur
There is more discussion about Redline fluid than the Mobil 1. I use the Mobil 1. After 20K miles, there was no wear on the magnetic plug. I just did a second 1x3 with the Redline Racing (2x3 total now) and most shifts feel exactly the same. Since you cannot get less than "no wear," I would say that the Mobil 1 is just fine. In any case, it is a billion times better than the Z1.
2003 Accord Coupe V6
I went with Amsoil Synthetic ATF. Redline is also good. If you want Mobil 1, you will want to make sure that the Mobil 1 Synthetic is compatible with honda/acura trannies and can replace the Honda ATF-Z1. the amsoil and redline website state that their ATF replaces ATF z1. I believe for a drain and refill it is 3.1qts.
Dogmatic Dinosaur
The mobil 1 syn in the grey bottle is a Dex III fluid which is what the amsoil and Redline D4 are. It says Honda Z1 suitable on the back of the bottle.
I've been using the Mobil 1 for about a month now. The back of the bottle says its compatible with the Honda factory fluid. I can't tell much of a difference although I know it'll be a lot better for it in the long run.
There is not an atf made that is not compatable with the 5at in the Tl that I'm aware of.
BANNED
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
